| Tdskip |
Sep 14 2020, 04:50 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,783 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Working on that white Fresno car and I have two rebuilt CV/axles but one has pins, two per side, and the other does not.
I have two spare (needig servicng) that have dowels - can I just lmoves the dowels over to the ready to use ones? Thanks, cranking to try to get this done and I really appreciate everybody’s help! (I did try searching first) |
| 914werke |
Sep 14 2020, 05:49 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,748 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Perhaps.
The issue I alluded to in another thread is that since 914 CV's are NLA it is typical to use T1 CV's in their place. BUT while dimension are similar, they are not the same. If that is what you have, the roll pins, dowels, spring pins (whatever) will not fit in the T1 CV without machining. Another giveaway is the T1 CV's will not have a recess machined for the use of a gasket. |
| Superhawk996 |
Sep 14 2020, 05:52 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,070 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
To further the response above.
Yes they are required. The prevent the two parts from moving relative to one another in shear. It would take way more clamp load then the four fasteners could provide to keep the surfaces from moving relative to one another under load. |
| 914werke |
Sep 14 2020, 06:30 PM
| Tdskip |
Sep 14 2020, 06:45 PM
Thank you very much for the responses, I will do some checking, I think they’re 914 but if so they’ve been messed with and, well, you know how that goes.
| Tdskip |
Sep 14 2020, 07:16 PM
Just to follow on here and be more explicit, should I assume if any of the axles do not have the dowels/alignment pins that they are probably not 914?
| Rob-O |
Sep 14 2020, 08:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,320 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region
| Mark Henry |
Sep 15 2020, 04:29 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Just to follow on here and be more explicit, should I assume if any of the axles do not have the dowels/alignment pins that they are probably not 914? Not necessarily. If I remember correctly the -6 CV’s have six bolts and no pins. For a /6 it depends on the year of the stubs, mine have the early 70's big CV's that have pins and M10 bolts, later are just six M10 bolts. VW CV's are six bolt, for 4 bolt 914 you can use VW T1 cv's, IIRC you have to enlarge two holes slightly to accept the pins. |
| Tdskip |
Sep 15 2020, 06:47 AM
Thanks for the information.
So with the VW ones “just” find the alignment pin size and take a drilll to open up two hole we’re the bolts would have gone? Anywhere special to get the alignment pins? |
| Tdskip |
Sep 15 2020, 10:37 AM
| Tdskip |
Sep 16 2020, 07:23 AM
Good morning. So I cleaned the various sets of these axles that I had laying around in preparation for rebuilding them.
I was able to confirm that this ring on the outside match is the known to be 914 CV joint/axles and the length is identical. So that seems to confirm that these are 914/6 axles? Any advantage to using these on a/six build or are the equivalent in strength to the four-cylinder 914 ones? To use the 6 foot ones I need a matching six bolt flange installed under the transmission I believe, yes? |
| Rob-O |
Sep 16 2020, 07:33 AM
A more definitive way to confirm would be to count the splines on the driveshaft/CV. I don’t remember off hand what the spline counts were but somebody here will chime in or Google is your friend.
I want to say 31 splines for the -6 and 36 splines for the -4. But that’s a WAG. |
| Mark Henry |
Sep 16 2020, 08:02 AM
Good morning. So I cleaned the various sets of these axles that I had laying around in preparation for rebuilding them. I was able to confirm that this ring on the outside match is the known to be 914 CV joint/axles and the length is identical. So that seems to confirm that these are 914/6 axles? Any advantage to using these on a/six build or are the equivalent in strength to the four-cylinder 914 ones? To use the 6 foot ones I need a matching six bolt flange installed under the transmission I believe, yes? There isn't a strength advantage 914/6 vs 914/4 axles. You would only get stronger axles by doing something like a 5 bolt conversion and using the 108mm hubs, stubs, CV's and Sway-A-Way axles. I agree with Rob-O count the splines and do a search. Eric has a good write up on the different kit you can use with a 5-bolt conversion. |
| Tdskip |
Sep 16 2020, 03:13 PM
I will get counting, thanks gentlemen.
Lo-Fi Version | Time is now: 21st September 2026 - 07:21 AM |
