draganc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States ![]() |
Hi folks!
I’m looking for targa vinyl adhesive recommendations and what products to stay away, I read Eric’s installation summary (thanks a bunch!!) but besides 3M didn’t find any specific p/n for 3M or other good adhesives. Who has used what and with what kind of experience? Car is fresh painted (about 3 months old) and I really don’t want to fudged it up with some “budget/mainstream” FLAPS stuff. Thanks in advance! dc |
jmitro |
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None ![]() ![]() |
post 43 he used 3M super 90.
that's what I used also. Same for the door panel cards |
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
![]() I agree, the best spray adhesive for this kind of stuff..... |
wysri9 |
Member ![]() ![]() Group: Members Posts: 199 Joined: 23-August 13 From: Aberdeen, Scotland Member No.: 16,291 Region Association: England ![]() ![]() |
I am at the same stage and was all set up (having read Eric's excellent description of the installation) with spray adhesive when an Upholsterer friend visited and recommended 3M double sided tape. I am not sure why I hadn't thought of it, as only days earlier I had had to clean off (its a long story...) a large amount of double sided tape from a bicycle frame. I can assure you it sticks like s*** to the proverbial blanket.....
Here are the results so far - seems to do a great job. I started off carefully positioning the side panels, holding them in place with masking tape, and then sticking the top 3-4 inches with tape laid around the perimeter of the sail panel. I then removed the masking tape, lifted up the lower section of the vinyl and held it up with more masking tape and then taped the rest of the perimete. Careful laid down the vinyl sticking one edge and carefully stretching towards the other edges. Finally I taped the sections where the vinyl folded over and stuck those down. The tape seems to "set" gradually and so repositioning is possible as is peeling off for a final trim. I was always a bit afraid of the finality of the spray adhesive approach, oh and there is no issue with overspray (IMG:style_emoticons/default/smile.gif) The tape seems much more controllable. Time will tell on the durability but my upholsterer friend assures me it will be fine. ![]() |
draganc |
Interesting approach about the double sided tape!
Do you have a p/n or description of it? I don’t know if it’s my phone, but your picture looks like that there are “lines” showing. In what pattern did you apply the tape for in between the edges? Cheers! ![]() |
draganc |
PS: Great color, orange was my first choice but hat to saddle with silver.
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,339 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
I've removed a lot of sail vinyl. They used old "gorilla snot" or what we call weldwood yellow contact cement. Also known as Formica glue. The old glue will remove with lacquer thinner, which will not harm the original enamel paint. Tape the bottom half of the bottom of the vinyl to the panel, and let the top part hang down where it's inside out. Glue both vinyl and panel. Let dry till your finger will not stick to the glue. Carefully, work the top half back into place, and use the palm of your hand to apply pressure to all the vinyl. Repeat on the bottom half.
moldygreg |
Stay Golden ![]() ![]() Group: Members Posts: 136 Joined: 13-December 12 From: Seattle Member No.: 15,253 Region Association: Pacific Northwest ![]() ![]() |
I struggled with 3M spray adhesive for the sail panel.
I used HH-66 Vinyl Cement and had good results. http://www.rhadhesives.com/hh-66-vinyl-cement.html Wurth makes a similiar product but is more difficult to track down. Good luck! |
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,565 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
DAP Weldwood Landau top and Trim adhesive. It's made for this. Only problem is you have to buy a gallon. But there are lots of other uses (dash, seats, etc.)
wysri9 |
Interesting approach about the double sided tape! Do you have a p/n or description of it? I don’t know if it’s my phone, but your picture looks like that there are “lines” showing. In what pattern did you apply the tape for in between the edges? Cheers! ![]() i used 3M 9088 Double Sided High Performance Clear Tape. Its 0.1mm thick and so invisible. I DID NOT use VMB foam tape which is incredibly sticky but also 1mm thick. I put tape around the perimeter of the panel initially and then "wrapped" the edges onto tape there. The vinyl stretched slightly as I formed it over the panel and stayed in position well once onto the tape. I guess you could add more rows of tape but my upholsterer friend suggested what I did. Time will tell..... (IMG:style_emoticons/default/smile.gif) |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,965 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Interesting approach about the double sided tape! Do you have a p/n or description of it? I don’t know if it’s my phone, but your picture looks like that there are “lines” showing. In what pattern did you apply the tape for in between the edges? Cheers! ![]() i used 3M 9088 Double Sided High Performance Clear Tape. Its 0.1mm thick and so invisible. I DID NOT use VMB foam tape which is incredibly sticky but also 1mm thick. I put tape around the perimeter of the panel initially and then "wrapped" the edges onto tape there. The vinyl stretched slightly as I formed it over the panel and stayed in position well once onto the tape. I guess you could add more rows of tape but my upholsterer friend suggested what I did. Time will tell..... (IMG:style_emoticons/default/smile.gif) wysri9. Thanks for the info. Sounds like the tape might be a great alternative to the spray. |
draganc |
Excellent feedback guys - very much appreciated!
The tape method sounds actually very interesting. |
dt4 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 503 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England ![]() ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,035 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I am about to install the floor vinyl and the double side tape sounds like a better way to go. Did not want to have a bunch of glue over spray.
gms |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,723 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest ![]() ![]() |
Lo-Fi Version | Time is now: 13th July 2025 - 03:02 AM |
