Cleaning Fuchs? |
Cleaning Fuchs? |
Freezin 914 |
Sep 17 2020, 12:12 PM
Senior Member Group: Members Posts: 872 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
Hey everybody, just put a set of 2.0 Fuchs on my car, looking for some suggestions on cleaning up the wheels, a bit dull and seem to be suffering from some oxidation.
I know 5 spoke Fuchs are anodized, honestly not sure about baby Fuchs. Attached image(s) |
Sep 17 2020, 12:41 PM
914-6 GT in waiting Group: Members Posts: 19,309 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
2.0 Fuchs are also anodized. I clean with dawn dish detergent, a soft brush and then use Vaseline - as recommended by Porsche.
rgolia |
Sep 17 2020, 12:42 PM
GeoJoe Group: Members Posts: 704 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
they are anodized and a pain to clean. I had mine redone as it became impossible to clean them
914_7T3 |
Sep 17 2020, 12:45 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
2.0 Fuchs are also anodized. I clean with dawn dish detergent, a soft brush and then use Vaseline - as recommended by Porsche. @mepstein Tell me more about Vaseline for the wheels only....so as to eliminate the need for all sorts of comments not applicable to this application. (IMG:style_emoticons/default/laugh.gif) |
Sep 17 2020, 01:04 PM
2.0 Fuchs are also anodized. I clean with dawn dish detergent, a soft brush and then use Vaseline - as recommended by Porsche. @mepstein Tell me more about Vaseline for the wheels only....so as to eliminate the need for all sorts of comments not applicable to this application. (IMG:style_emoticons/default/laugh.gif) I don’t know where it’s listed but it’s known to be recommended by Porsche. Try it. It sure can’t hurt anything. Also works well on the rubber bumper tops. Apply heavy, let warm in sun and buff off excess. |
Superhawk996 |
Sep 17 2020, 01:27 PM
914 Guru Group: Members Posts: 5,886 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
. . . use Vaseline - as recommended by Porsche. (IMG:style_emoticons/default/av-943.gif) cue the scene from Deliverance |
Superhawk996 |
Sep 17 2020, 04:34 PM
@freezin 914
Didn't catch that you were OP. Good to see you back on-line and posting. That car looks even better out in the sun! |
Mark Henry |
Sep 17 2020, 04:55 PM
I wax my polished Fuchs every spring. The big cleaning tip is to get the brake dust off ASAP, the stuff is acidic (or like acid) as heck. I wipe the brake dust off at least once a week.
Biggles |
Sep 18 2020, 06:20 AM
Member Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
FWIW I use ACF50 spray used in the aircraft and bike sector. Dont know if you get it in the US. Been applying a thin coat of this for a couple of years and does a great job.
914_7T3 |
Sep 18 2020, 02:56 PM
FWIW I use ACF50 spray used in the aircraft and bike sector. Dont know if you get it in the US. Been applying a thin coat of this for a couple of years and does a great job. @Biggles This stuff? "ACF-50 actively penetrates and "creeps" into the tightest seams, lap joints, micro cracks, and around rivet heads, displacing moisture and other corrosive fluids in these corrosive prone areas." https://www.youtube.com/watch?v=30paBTt8Oko |
Freezin 914 |
Sep 18 2020, 07:57 PM
@freezin 914 Didn't catch that you were OP. Good to see you back on-line and posting. That car looks even better out in the sun! Thank you sir, the pictures look better than it is in person, this one is new to me. Bought it in July. (IMG:style_emoticons/default/beerchug.gif) |
Biggles |
Sep 19 2020, 11:08 AM
FWIW I use ACF50 spray used in the aircraft and bike sector. Dont know if you get it in the US. Been applying a thin coat of this for a couple of years and does a great job. @Biggles This stuff? "ACF-50 actively penetrates and "creeps" into the tightest seams, lap joints, micro cracks, and around rivet heads, displacing moisture and other corrosive fluids in these corrosive prone areas." https://www.youtube.com/watch?v=30paBTt8Oko Yes that's the stuff. You dont need a lot. A thin mist coat wiped with a rag. Muck will stick to it a bit but it would probably do that with vaseline. |
Lo-Fi Version | Time is now: 4th June 2024 - 06:01 PM |
