Machine shop time, How many hours to prep case, crank, bearings? |
Phoenix914 |
Sep 17 2020, 06:21 PM
Member Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States |
Greetings All!
I just recently dropped off my 2.0 (GA) case and 71mm crankshaft to get checked at a local machine shop in preparation for a rebuild. Today they called and said for align bore, decking the registers, polishing the crankshaft, and mocking up the assembly with fitted and numbered main bearings it would be 30 hours of work. Does that sound reasonable? It's honestly a lot more than I expected and will add $$$ to my budget for this rebuild. Should I look for another case, maybe a 1.7, that is in better condition or has already been prepped? I'm not an expert builder and some things are worth paying for, but man that's a lot of money! Thanks for any advice! |
Jack Standz |
Dec 3 2020, 11:12 PM
Member Group: Members Posts: 277 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
New Empie rods that are supposedly better/lighter than H-Beam rods. I'm also using tool steel type 1 lifters and aluminum pushrods, etc. To keep valve train weight down in a 2.7 liter (4 cylinder) project I've got going (among many others).
https://www.aircooledvintageworks.com/produ...=32332313002029 But, if you want to go with the H-Beam rods, why not the new I-Beam Empis?? |
914werke |
Dec 4 2020, 12:02 AM
"I got blisters on me fingers" Group: Members Posts: 10,059 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
New Empie rods that are supposedly better/lighter than H-Beam rods. I'm also using tool steel type 1 lifters and aluminum pushrods, etc. To keep valve train weight down in a 2.7 liter (4 cylinder) project I've got going (among many others). https://www.aircooledvintageworks.com/produ...=32332313002029 But, if you want to go with the H-Beam rods, why not the new I-Beam Empis?? Cuz were working on T4's here ? |
Jack Standz |
Dec 4 2020, 11:15 AM
New Empie rods that are supposedly better/lighter than H-Beam rods. I'm also using tool steel type 1 lifters and aluminum pushrods, etc. To keep valve train weight down in a 2.7 liter (4 cylinder) project I've got going (among many others). https://www.aircooledvintageworks.com/produ...=32332313002029 But, if you want to go with the H-Beam rods, why not the new I-Beam Empis?? Cuz were working on T4's here ? Cuz we're working on modifying a T4 with aftermarket parts to get a combination that will meet our goals? Or you can always keep it bone stock (IMG:style_emoticons/default/smile.gif). T1 rod journals are larger and used by many T4 builders (and T1 lifters are lots lighter than T4 lifters). |
Lo-Fi Version | Time is now: 15th May 2024 - 08:57 PM |
