FS Restored Rear Targa Latches, early and late, $90 per pair shipped. Cores requested |
bdstone914 |
Sep 18 2020, 02:08 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Edit 10/28/2020:
1 more pair of late latches and two pair of early latches available. These have the plastic removed and are powder coated satin black. New spring are made and installed with a stronger push on fastener for the hook. Note the difference between early and late latches. The early latches have lower locating bumps that are farther apart. Late latches have taller bumps and that are closer together. Compare to what is on your car. Early should be 70-72 and late from 73 on. The latch must mate to the rubber block on the top to fit properly. I have two pairs of early and late latches finished. I have finish parts to make several ore pair. I request your old latches in return so I can continue offering these. It is ok if the hooks are missing as I have the reproduced. $90 per pair shipped. Attached thumbnail(s) |
BPic |
Sep 18 2020, 02:11 PM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
I'll take 2 Early please! I'll send PM shortly for arrangements to send cores.
914Sixer |
Sep 18 2020, 02:25 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Bruce, I may have 6-8 cores.
bdstone914 |
Sep 18 2020, 02:35 PM
@BPic
' date='Sep 18 2020, 01:11 PM' post='2852339'] I'll take 2 Early please! I'll send PM shortly for arrangements to send cores. [/quote] To clarify you want one set of one left and one right early latch, correct? |
BPic |
Sep 18 2020, 03:22 PM
[quote name='bdstone914' date='Sep 18 2020, 04:35 PM' post='2852350']
@BPic ' date='Sep 18 2020, 01:11 PM' post='2852339'] I'll take 2 Early please! I'll send PM shortly for arrangements to send cores. [/quote] To clarify you want one set of one left and one right early latch, correct? [/quote] Yes please! |
Gint |
Sep 20 2020, 12:34 PM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I need a set of early Bruce. I don't have cores. I might, but they're buried somewhere. If at some later date I'm digging through stash and find a set I would gladly send them your way.
yellowporky |
Sep 20 2020, 05:20 PM
Member Group: Members Posts: 422 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
I will take a pair of late.
Thanks Chris |
JamesJ |
Sep 20 2020, 09:10 PM
Member Group: Members Posts: 220 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
I will take a set of late latches if still available. Thank you.
pete000 |
Sep 20 2020, 10:29 PM
I like the push fastener idea ! I have struggled with the "C" clips falling off. I ended up using "E" clops, but like your approach better !
bdstone914 |
Sep 20 2020, 10:45 PM
@Gint
' date='Sep 20 2020, 11:34 AM' post='2852762'] I need a set of early Bruce. I don't have cores. I might, but they're buried somewhere. If at some later date I'm digging through stash and find a set I would gladly send them your way. [/quote] Thats cool. Paypay is my screename at Aol.com |
bdstone914 |
Sep 20 2020, 10:50 PM
@pete000 +
date='Sep 20 2020, 09:29 PM' post='2852958'] I like the push fastener idea ! I have struggled with the "C" clips falling off. I ended up using "E" clops, but like your approach better ! [/quote] I went through 3 different types until i found these. We used to use them to hold on electric fan blades. The problem is the posts are worn and more lateral forces are placed on the hooks. The only down side is they qre q one use fastener. You can drive them on to remove the slop on the post. |
bdstone914 |
Sep 20 2020, 10:55 PM
914werke |
Sep 22 2020, 12:15 PM
"I got blisters on me fingers" Group: Members Posts: 10,004 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Bruce just to clarify the early & late ARE interchangeable but would also have to change the corresponding rub block ?
I also have SEVERAL sets of cores & what I found was there is also a style change. It seems that on the some early latches the body was stainless vs the later painted or coated mild steel. |
bdstone914 |
Sep 22 2020, 03:23 PM
@914werke
' date='Sep 22 2020, 11:15 AM' post='2853387'] Bruce just to clarify the early & late ARE interchangeable but would also have to change the corresponding rub block ? I also have SEVERAL sets of cores & what I found was there is also a style change. It seems that on the some early latches the body was stainless vs the later painted or coated mild steel. [/quote] I dont know if they are interchangable. The later blocks are also taller. The window seals are different too.I want to try it to find out. Some early latches were chrome not stainless. Do you want to trade for the cores? I more need late cores. |
914werke |
Sep 22 2020, 06:59 PM
Do you want to trade for the cores? I more need late cores. Absolutely Ill ring you. (IMG:style_emoticons/default/smile.gif) |
pete000 |
Sep 26 2020, 10:36 PM
my 1970 914-6 are chrome.
Garland |
Sep 26 2020, 11:43 PM
Restoration Fanatic Group: Members Posts: 1,327 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
My 70 914-4, were, also Chrome
bdstone914 |
Sep 27 2020, 09:47 AM
bdstone914 |
Oct 6 2020, 09:34 AM
Bruce just to clarify the early & late ARE interchangeable but would also have to change the corresponding rub block ? I also have SEVERAL sets of cores & what I found was there is also a style change. It seems that on the some early latches the body was stainless vs the later painted or coated mild steel. They may be interchangable it the block is changed. I have not tried to swap the block to verify. In addition to the later blocks |
Jgilliam914 |
Oct 6 2020, 07:24 PM
914 Guru Group: Members Posts: 5,327 Joined: 30-July 12 From: Iowa / Florida Member No.: 14,732 Region Association: Upper MidWest |
Bruce I will take a set for a 72
I know I have the cores but it might take me awhile to find them |
Lo-Fi Version | Time is now: 25th April 2024 - 10:21 PM |
