bdstone914
Sep 18 2020, 02:08 PM
Edit 10/28/2020:
1 more pair of late latches and two pair of early latches available.
These have the plastic removed and are powder coated satin black.
New spring are made and installed with a stronger push on fastener for the hook.
Note the difference between early and late latches. The early latches have lower locating bumps that are farther apart. Late latches have taller bumps and that are closer together.
Compare to what is on your car. Early should be 70-72 and late from 73 on.
The latch must mate to the rubber block on the top to fit properly.
I have two pairs of early and late latches finished. I have finish parts to make several ore pair.
I request your old latches in return so I can continue offering these. It is ok if the hooks are missing as I have the reproduced.
$90 per pair shipped.
BPic
Sep 18 2020, 02:11 PM
I'll take 2 Early please! I'll send PM shortly for arrangements to send cores.
914Sixer
Sep 18 2020, 02:25 PM
Bruce, I may have 6-8 cores.
bdstone914
Sep 18 2020, 02:35 PM
@BPic ' date='Sep 18 2020, 01:11 PM' post='2852339']
[/quote]
To clarify you want one set of one left and one right early latch, correct?
BPic
Sep 18 2020, 03:22 PM
[quote name='bdstone914' date='Sep 18 2020, 04:35 PM' post='2852350']
[/quote]
[/quote]
Yes please!
Gint
Sep 20 2020, 12:34 PM
I need a set of early Bruce. I don't have cores. I might, but they're buried somewhere. If at some later date I'm digging through stash and find a set I would gladly send them your way.
yellowporky
Sep 20 2020, 05:20 PM
I will take a pair of late.
Thanks
Chris
JamesJ
Sep 20 2020, 09:10 PM
I will take a set of late latches if still available. Thank you.
pete000
Sep 20 2020, 10:29 PM
I like the push fastener idea ! I have struggled with the "C" clips falling off. I ended up using "E" clops, but like your approach better !
bdstone914
Sep 20 2020, 10:45 PM
@Gint ' date='Sep 20 2020, 11:34 AM' post='2852762']
[/quote]
Thats cool.
Paypay is my screename at Aol.com
bdstone914
Sep 20 2020, 10:50 PM
@pete000 +
date='Sep 20 2020, 09:29 PM' post='2852958']
[/quote]
I went through 3 different types until i found these. We used to use them to hold on electric fan blades. The problem is the posts are worn and more lateral forces are placed on the hooks. The only down side is they qre q one use fastener. You can drive them on to remove the slop on the post.
bdstone914
Sep 20 2020, 10:55 PM
QUOTE(JamesJ @ Sep 20 2020, 08:10 PM)
PayPal is bdstone914@aol.com
Do you have any cores you can return later?
I can send postage for them.
Bruce
914werke
Sep 22 2020, 12:15 PM
Bruce just to clarify the early & late ARE interchangeable but would also have to change the corresponding rub block ?
I also have SEVERAL sets of cores & what I found was there is also a style change.
It seems that on the some early latches the body was stainless vs the later painted or coated mild steel.
bdstone914
Sep 22 2020, 03:23 PM
@914werke ' date='Sep 22 2020, 11:15 AM' post='2853387']
[/quote]
I dont know if they are interchangable. The later blocks are also taller. The window seals are different too.I want to try it to find out.
Some early latches were chrome not stainless.
Do you want to trade for the cores? I more need late cores.
914werke
Sep 22 2020, 06:59 PM
QUOTE(bdstone914 @ Sep 22 2020, 02:23 PM)
Absolutely Ill ring you.
pete000
Sep 26 2020, 10:36 PM
my 1970 914-6 are chrome.
Garland
Sep 26 2020, 11:43 PM
My 70 914-4, were, also Chrome
bdstone914
Sep 27 2020, 09:47 AM
QUOTE(Garland @ Sep 26 2020, 10:43 PM)
I have always wonder where the chrome latches were used. There is not a different par number for them. Anyone have a 71 or 72 with chrome latches?
Bruce
bdstone914
Oct 6 2020, 09:34 AM
QUOTE(914werke @ Sep 22 2020, 11:15 AM)
They may be interchangable it the block is changed. I have not tried to swap the block to verify. In addition to the later blocks
Jgilliam914
Oct 6 2020, 07:24 PM
Bruce I will take a set for a 72
I know I have the cores but it might take me awhile to find them
ahycaramba
Oct 15 2020, 10:24 PM
Hi Bruce, Do you still have a set of restored late version latches available, If so i'l take one set.
Thanks.
Al
bdstone914
Oct 16 2020, 09:24 AM
QUOTE(ahycaramba @ Oct 15 2020, 09:24 PM)
Thanks.
Al
Yes, PM sent
bdstone914
Oct 28 2020, 09:25 AM
bump
cary
Dec 30 2020, 03:20 PM
Need a set of earlys for the 916 restoration.
jrrobertson
Jan 4 2021, 12:51 PM
If they are still available I need a set of early latches.
bdstone914
Jan 4 2021, 12:54 PM
QUOTE(jrrobertson @ Jan 4 2021, 12:51 PM)
Yes PM sent
rgalla9146
Jan 4 2021, 06:07 PM
QUOTE(pete000 @ Sep 20 2020, 11:29 PM)
Great solution to a near universal problem.......actually two problems.
The 'lobster claw' clip was no longer dependable on an oxidised post and when it
was firm it didn't remove excess wobble on the hook. Excellent innovation Bruce.
Seems to me early cars ('70-'72 ?) had a chrome plated flat rest for the rubber
block attached to the roof. Later cars it was black
bdstone914
Jan 4 2021, 10:46 PM
QUOTE(rgalla9146 @ Jan 4 2021, 06:07 PM)
Yes some early cars had chrome housings. But i just pulled a pair from a 70 that were black. May have been tied to the apoearance group package.
bbrock
Jan 5 2021, 06:39 PM
QUOTE(bdstone914 @ Jan 4 2021, 09:46 PM)
My non-appearance group April 73 2L has one of each. Originally had one early and one late rear brake caliper too.
Jan 5 2021, 07:56 PM
My 70 parts car had chrome but both my 71's are black.
partwerks
Jan 5 2021, 08:43 PM
Do you buy cores?
bdstone914
Jan 5 2021, 09:44 PM
QUOTE(partwerks @ Jan 5 2021, 08:43 PM)
Do you buy cores?
@partwerks I would rather trade for parts. I have a good supply at this time. What do you have,? Early or late, how many pairs?
mmichalik
Jan 6 2021, 09:22 AM
Hi Bruce,
If you still have some, I will take a set for my '75.
I have 4 cores I can return along with the pedal box core as well.
Thanks,
Mike
bdstone914
Jan 6 2021, 11:12 AM
QUOTE(mmichalik @ Jan 6 2021, 09:22 AM)
Hi Bruce,
Thanks,
Mike
You have a PM
partwerks
Jan 9 2021, 08:53 PM
QUOTE(bdstone914 @ Jan 5 2021, 07:44 PM)
Do you buy cores?
Was just inquiring in case I come across some.
bdstone914
Mar 28 2021, 12:04 PM
Bump. Still available.
PCABATMAN
Mar 28 2021, 12:22 PM
QUOTE(bdstone914 @ Mar 28 2021, 11:04 AM)
I sent a PM for 74 latches. Thanks
914 chalon v8
Jun 16 2021, 09:44 PM
How do I go about getting a set of the rear targa latches for a 1972 914 ?
bdstone914
Jun 17 2021, 09:14 AM
QUOTE(914 chalon v8 @ Jun 16 2021, 08:44 PM)
@914 chalon v8 I have a set.
914outlaw
Jul 27 2021, 12:12 PM
Do you have any restored Pedal clusters?
@bdstone914
bdstone914
Jul 27 2021, 02:27 PM
QUOTE(914outlaw @ Jul 27 2021, 11:12 AM)
@bdstone914Yes. PM sent
@914outlaw
