FS Restored Rear Targa Latches, early and late, $90 per pair shipped. Cores requested |
bdstone914 |
Sep 18 2020, 02:08 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Edit 10/28/2020:
1 more pair of late latches and two pair of early latches available. These have the plastic removed and are powder coated satin black. New spring are made and installed with a stronger push on fastener for the hook. Note the difference between early and late latches. The early latches have lower locating bumps that are farther apart. Late latches have taller bumps and that are closer together. Compare to what is on your car. Early should be 70-72 and late from 73 on. The latch must mate to the rubber block on the top to fit properly. I have two pairs of early and late latches finished. I have finish parts to make several ore pair. I request your old latches in return so I can continue offering these. It is ok if the hooks are missing as I have the reproduced. $90 per pair shipped. Attached thumbnail(s) |
Gint |
Sep 20 2020, 12:34 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I need a set of early Bruce. I don't have cores. I might, but they're buried somewhere. If at some later date I'm digging through stash and find a set I would gladly send them your way.
bdstone914 |
Sep 20 2020, 10:45 PM
@Gint
' date='Sep 20 2020, 11:34 AM' post='2852762'] I need a set of early Bruce. I don't have cores. I might, but they're buried somewhere. If at some later date I'm digging through stash and find a set I would gladly send them your way. [/quote] Thats cool. Paypay is my screename at Aol.com |
Lo-Fi Version | Time is now: 19th May 2024 - 01:29 AM |
