FS Restored Rear Targa Latches, early and late, $90 per pair shipped. Cores requested |
bdstone914 |
Sep 18 2020, 02:08 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Edit 10/28/2020:
1 more pair of late latches and two pair of early latches available. These have the plastic removed and are powder coated satin black. New spring are made and installed with a stronger push on fastener for the hook. Note the difference between early and late latches. The early latches have lower locating bumps that are farther apart. Late latches have taller bumps and that are closer together. Compare to what is on your car. Early should be 70-72 and late from 73 on. The latch must mate to the rubber block on the top to fit properly. I have two pairs of early and late latches finished. I have finish parts to make several ore pair. I request your old latches in return so I can continue offering these. It is ok if the hooks are missing as I have the reproduced. $90 per pair shipped. Attached thumbnail(s) |
914werke |
Sep 22 2020, 12:15 PM
"I got blisters on me fingers" Group: Members Posts: 10,062 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Bruce just to clarify the early & late ARE interchangeable but would also have to change the corresponding rub block ?
I also have SEVERAL sets of cores & what I found was there is also a style change. It seems that on the some early latches the body was stainless vs the later painted or coated mild steel. |
bdstone914 |
Sep 22 2020, 03:23 PM
@914werke
' date='Sep 22 2020, 11:15 AM' post='2853387'] Bruce just to clarify the early & late ARE interchangeable but would also have to change the corresponding rub block ? I also have SEVERAL sets of cores & what I found was there is also a style change. It seems that on the some early latches the body was stainless vs the later painted or coated mild steel. [/quote] I dont know if they are interchangable. The later blocks are also taller. The window seals are different too.I want to try it to find out. Some early latches were chrome not stainless. Do you want to trade for the cores? I more need late cores. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:58 AM |
