Install Question on the Brad Mayeur external kit, Install Question on the Brad Mayeur external kit |
ri914 |
Sep 19 2020, 01:28 PM
Member Group: Members Posts: 102 Joined: 13-August 20 From: rhode island Member No.: 24,593 Region Association: North East States |
Hello 914ers,
I am finishing up some metal work today and am going to tackle Brads 914ltd external reinforcement kit. I have a few questions though.... 1: Is it better to install this with the engine in our out? 2: Is it better to weld this in on a lift or on the ground? I imagine the answer is a combo of the 2 questions above. Since part of the install is to remove the bolts on the trailing arm I though it better to see what the experts thought first. thank you Ben- lift point for kit trailing arm bolts |
IronHillRestorations |
Sep 19 2020, 03:34 PM
I. I. R. C. Group: Members Posts: 6,726 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You don’t have to remove the engine but you have to take off the outer trailing arm mount as the stiffener is your first alignment shim.
I’d do it on a lift, as long as your measurements are on the money. I’ve installed a few of these. I’ve got a set of Jorgensen Mastadon jaws for a bar clamp, which is very helpful. I also cut some small “windows “ in the sills, above each of the vertical ribs on the factory longs, so I can weld a bead there too. Longitudinal stiffener thread. See post # 26 |
ri914 |
Sep 19 2020, 03:50 PM
You don’t have to remove the engine but you have to take off the outer trailing arm mount as the stiffener is your first alignment shim. I’d do it on a lift, as long as your measurements are on the money. I’ve installed a few of these. I’ve got a set of Jorgensen Mastadon jaws for a bar clamp, which is very helpful. I also cut some small “windows “ in the sills, above each of the vertical ribs on the factory longs, so I can weld a bead there too. Longitudinal stiffener thread. See post # 26 Perry thank you so much. This is very helpful. |
Lo-Fi Version | Time is now: 4th June 2024 - 03:25 PM |
