Master brake cylinder, Not sure on electrical |
Morph914 |
Sep 20 2020, 10:14 AM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
When I took the old master cylinder off, these 2 wires were dangling next to it. Do I have the wrong sensor, is there a 2 prong? How can I make this work?
Thanks in advance, John |
mepstein |
Sep 20 2020, 10:34 AM
914-6 GT in waiting Group: Members Posts: 19,284 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Just tape off one of the brown wires and connect the other. It works fine that way.
Morph914 |
Sep 20 2020, 12:58 PM
914Sixer |
Sep 20 2020, 01:18 PM
914 Guru Group: Members Posts: 8,889 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Make sure you put a boot over it.
Mikey914 |
Sep 20 2020, 02:07 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
P me your shipping If you don't have one I'll send one out.
-Mark |
ri914 |
Sep 20 2020, 08:07 PM
Member Group: Members Posts: 102 Joined: 13-August 20 From: rhode island Member No.: 24,593 Region Association: North East States |
Mikey914 |
Sep 20 2020, 09:16 PM
The single prong makes thr circuit through the body of the casting. The dual prong (factory version) had 2 prongs.
When we made our 1st batch of these they were machined just like factory. We couldn't find a 2 pole sensor in the correct size. So we had to use a single. It does exactly the same thing but as I mentioned the circuit is completed differently. The good news is we did find a 2 pole sensor for this next batch we are doing, it just has a different thread than the stock. So it will work on our new ones, but is not retrofit compatible with what we had made. Sorry about that. Just couldn't find one that was a quality part that we could use. |
lierofox |
Sep 21 2020, 01:35 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
Just tape off one of the brown wires and connect the other. It works fine that way. Great! Thank you If you decide to stick with the current switch, specifically tape off the brown wire, and connect the brown wire with the white stripe to the terminal. |
Lo-Fi Version | Time is now: 23rd May 2024 - 06:03 PM |
