replacement fuel injector connectors? |
AndrewBlyholder |
Sep 22 2020, 12:34 PM
Member Group: Members Posts: 109 Joined: 20-September 04 From: Richmond, CA Member No.: 2,791 |
One of the spade connectors for the distributor trigger points plug broke off yesterday on my D-jet 2.0. This is on a F.I. harness I rebuilt myself several decades ago. At that time, I got exact replacements for the factory spade connectors from a place in LA. They don't seem to exist any more. Anyone know a part number from Digi-key for these?
Browsing the Digi-Key website, I've found 12 possible matches, all more or less the same. Minor differences in stated wire gauge range. Some are phosphor bronze, some are brass. Some for .20" tab thickness, some for .32" tab thickness. Recommendations? Thanks, Andrew Blyholder |
IronHillRestorations |
Sep 22 2020, 01:49 PM
I. I. R. C. Group: Members Posts: 6,714 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
One of the spade connectors for the distributor trigger points plug broke off yesterday on my D-jet 2.0. This is on a F.I. harness I rebuilt myself several decades ago. At that time, I got exact replacements for the factory spade connectors from a place in LA. They don't seem to exist any more. Anyone know a part number from Digi-key for these? Browsing the Digi-Key website, I've found 12 possible matches, all more or less the same. Minor differences in stated wire gauge range. Some are phosphor bronze, some are brass. Some for .20" tab thickness, some for .32" tab thickness. Recommendations? Thanks, Andrew Blyholder I've seen them on eBay, with boots |
JamesM |
Sep 22 2020, 02:44 PM
Senior Member Group: Members Posts: 1,890 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Mikey914 |
Sep 22 2020, 05:05 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We are about to do a group buy on these. We have been making the complete harnesses but thought there might be a few of you that need these
JeffBowlsby |
Sep 22 2020, 10:14 PM
914 Wiring Harnesses Group: Members Posts: 8,484 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Some FI harness parts are also available at NAPA.
913B |
Sep 22 2020, 11:07 PM
Senior Member Group: Members Posts: 845 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Since the title of your post says you are looking for the fuel injector connectors.
Part number 63241-3 @ 15 cents each from Digi-Key was a perfect match. http://www.914world.com/bbs2/index.php?sho...=347991&hl= |
AndrewBlyholder |
Sep 23 2020, 12:03 PM
Ahhh! I didn't know about Retro Parts. Perfect!!
Not a fan of the replacement boots. They look so clunky compared to the originals, but I guess they're the only option for us at this point. Thanks. |
JamesM |
Sep 23 2020, 01:49 PM
Ahhh! I didn't know about Retro Parts. Perfect!! Not a fan of the replacement boots. They look so clunky compared to the originals, but I guess they're the only option for us at this point. Thanks. Maybe someone had previously swapped the boots on your harness? The ones I have look exactly like what i have on multiple harnesses except where the original harness the boots were 2 different colors for the injector banks. |
Sep 23 2020, 04:44 PM
Here's a kit for the injectors. Doesn't help for the distributor connection.
Injector connector and boot |
windforfun |
Sep 23 2020, 06:08 PM
Senior Member Group: Members Posts: 1,776 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Spade lug connectors are a dime a dozen. Buy some different sizes. Crimp the connection first & then solder it. 1" or so of shrink tubing is always a good idea. Don't cut any wire strands while stripping the insulation. This is how MB does their spade lugs.
JeffBowlsby |
Sep 23 2020, 06:29 PM
dr914@autoatlanta.com |
Sep 23 2020, 07:19 PM
914 Guru Group: Members Posts: 7,820 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yup plenty on the shelf
One of the spade connectors for the distributor trigger points plug broke off yesterday on my D-jet 2.0. This is on a F.I. harness I rebuilt myself several decades ago. At that time, I got exact replacements for the factory spade connectors from a place in LA. They don't seem to exist any more. Anyone know a part number from Digi-key for these? Browsing the Digi-Key website, I've found 12 possible matches, all more or less the same. Minor differences in stated wire gauge range. Some are phosphor bronze, some are brass. Some for .20" tab thickness, some for .32" tab thickness. Recommendations? Thanks, Andrew Blyholder |
Mikey914 |
Sep 24 2020, 12:21 AM
I offered up a new kit of all connectors with the plastic holders and boots, we are making simply for PM'ing me your address. No response. (IMG:style_emoticons/default/confused24.gif)
Robson51 |
Sep 24 2020, 01:05 PM
Member Group: Members Posts: 88 Joined: 18-November 19 From: seattle Member No.: 23,654 Region Association: Pacific Northwest |
Mikey914 |
Sep 25 2020, 11:34 AM
Yes
Lo-Fi Version | Time is now: 28th April 2024 - 01:42 PM |
