Parking brake lever, Need hardware |
Morph914 |
Sep 22 2020, 01:15 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
Where can I find the plastic bushing and the pin that holds the cable on for this handle?
My pin was badly rusted and is no longer usable. I will also need the c clip or other to hold the pin in place. Cheers, John |
Frankvw |
Sep 22 2020, 01:49 PM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
for the bushing, just google on part 914 424 247 00
several vendors will pop up. Good you got it out, must have been a struggle to get it out.... |
solex |
Sep 22 2020, 02:28 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
I just restored my parking brake, you can flip the bushing, mine had uneven wear on one side once flipped there is much less play. I could not get the cable pin out and has to cut / drill mine. I replaced it with a drilled pin and clevis similar to:
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.zoro.com-3439-1600806531.1.JPG) |
bbrock |
Sep 22 2020, 05:40 PM
The bushing is still available through Porsche and is cheap. I think the pin is too but can't remember for sure.
bdstone914 |
Sep 22 2020, 06:17 PM
bdstone914 Group: Members Posts: 4,516 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Morph914
' date='Sep 22 2020, 12:15 PM' post='2853404'] Where can I find the plastic bushing and the pin that holds the cable on for this handle? My pin was badly rusted and is no longer usable. I will also need the c clip or other to hold the pin in place. Cheers, John [/quote] Use a clutch clevis pin. Works great. I use a bronze bushing in place of the plastic one. I get them from Mcmaster-Carr.com |
Morph914 |
Sep 22 2020, 07:51 PM
Thanks for the info, I went on the local Porsche dealer site but they were asking for part #s. Thank you Frankvw for the bushing #, anyone know the pin #? If not I will check Ace or Tractor supply for a clevis pin.
Cheers, John |
bkrantz |
Sep 22 2020, 08:26 PM
914 Guru Group: Members Posts: 7,754 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Thanks for the info, I went on the local Porsche dealer site but they were asking for part #s. Thank you Frankvw for the bushing #, anyone know the pin #? If not I will check Ace or Tractor supply for a clevis pin. Cheers, John Every 914 part and number you will ever need. https://www.porsche.com/all/media/pdf/origi...914_KATALOG.pdf |
914e |
Sep 22 2020, 09:14 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
Thanks for the info, I went on the local Porsche dealer site but they were asking for part #s. Thank you Frankvw for the bushing #, anyone know the pin #? If not I will check Ace or Tractor supply for a clevis pin. Cheers, John The original part 91442457101 is NLA The replacement is 99916601002 The clip should be N0126452 |
bdstone914 |
Sep 22 2020, 09:17 PM
@Morph914
' date='Sep 22 2020, 06:51 PM' post='2853521'] Thanks for the info, I went on the local Porsche dealer site but they were asking for part #s. Thank you Frankvw for the bushing #, anyone know the pin #? If not I will check Ace or Tractor supply for a clevis pin. Cheers, John [/quote] If the dealer wants a part number tell them to look up the clutch clevis pin for a 914 or 911 from 1965-1989. If you go with non standard parts you need to get the right length pin. If it is loo long it can rub on the e brake mount. |
Lo-Fi Version | Time is now: 7th May 2024 - 08:24 PM |
