Squeaky Front End, Can't Find It |
windforfun |
Sep 22 2020, 03:16 PM
Senior Member Group: Members Posts: 1,791 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
There are squeaks on both side of the front end. I can't eliminate them with lubricant.
The hardware is original with a sway bar & 48K miles. Any suggestions? Thank you. |
BillC |
Sep 22 2020, 03:52 PM
Senior Member Group: Members Posts: 538 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
It's probably your torsion bars rubbing on the crossmember. The only real fix is to replace the control arm bushings. If the torsion bars are badly worn, they'll need to be replaced too.
Lo-Fi Version | Time is now: 19th May 2024 - 03:40 PM |
