Squeaky Front End, Can't Find It |
windforfun |
Sep 22 2020, 03:16 PM
Senior Member Group: Members Posts: 1,791 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
There are squeaks on both side of the front end. I can't eliminate them with lubricant.
The hardware is original with a sway bar & 48K miles. Any suggestions? Thank you. |
Mikey914 |
Sep 22 2020, 05:03 PM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Can happen as the rubber gets hard over time (and yes will shrink over time) so youmay be hearing some slight movement.
If you haven't replaced these I would suspect this is your issue - https://914rubber.com/front-control-arm-bus...th-install-tool Attached thumbnail(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 02:43 PM |
