Squeaky Front End, Can't Find It |
windforfun |
Sep 22 2020, 03:16 PM
Senior Member Group: Members Posts: 1,791 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
There are squeaks on both side of the front end. I can't eliminate them with lubricant.
The hardware is original with a sway bar & 48K miles. Any suggestions? Thank you. |
RickS |
Sep 22 2020, 10:00 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Is your sway bar through the body? If it is, it could be rubbing on the bottom of the fuel tank.
I had an Elephant through the body type added using drop links. It squeaks like crazy when warm. Some type of thermo expansion thing. If the weathers cool, no issue. I have used every lubricant known to man used on the drop links and metal to metal contacts with no luck. Disconnect the drop links, no squeaks. Gets very annoying on a long drive with every bump. Sound familiar? Very interested in your resolution. |
Lo-Fi Version | Time is now: 19th May 2024 - 12:36 PM |
