Where should the starter solenoid show up in the engine bay? |
Tdskip |
Sep 23 2020, 07:58 AM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning. Brought the electrical system up on the Fresno 914 - so far so good.
Well, mostly so far so good. My starter solenoid wiring is missing in (in)action. I believe that wiring comes through the tunnel in the cabin but where should it exit the firewall? Once this is sorted I should be able to time it and see if I can get it fired on a temporary fuel tank while the original one is being coated. Thanks! |
JeffBowlsby |
Sep 23 2020, 08:27 AM
914 Wiring Harnesses Group: Members Posts: 8,479 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Is this a trick question? It’s on the starter motor.
TheCabinetmaker |
Sep 23 2020, 08:42 AM
Jeff, l think he means from the relay board the the starter.
Tdskip |
Sep 23 2020, 09:12 AM
Ha, yes, wiring to the starter solenoid to activate the starter.
I have power there, need to find the female lead that goes to the spade on the solenoid that responds to the ignition key. Sorry for posting before having adequate coffee. Looks like it shows up here, so there should be a lead coming off this to the spade on the solenoid? |
GregAmy |
Sep 23 2020, 10:22 AM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
The stock design is for the wire to come from the ignition switch, back through the car harness and into the replay plate via the 14-pin connector pin 1, through the relay plate to the 12-pin connector pin 6 (your diagram), then a yellow wire from there through the rear firewall to the starter solenoid.
Just to clarify, the stock design does not incorporate a separate relay solenoid. So I'm guessing car won't crank? Pull the T12 connector and see if you get 12V when the key is turned to the start position. |
Tdskip |
Sep 23 2020, 10:28 AM
The stock design is for the wire to come from the ignition switch, back through the car harness and into the replay plate via the 14-pin connector pin 1, through the relay plate to the 12-pin connector pin 6 (your diagram), then a yellow wire from there through the rear firewall to the starter solenoid. Just to clarify, the stock design does not incorporate a separate relay solenoid. So I'm guessing car won't crank? Pull the T12 connector and see if you get 12V when the key is turned to the start position. Good morning and thanks, let me get a multimeter on that and see if I get power there and if I can find the darn lead to the solenoid. Time for some 914 archeology! |
Tdskip |
Sep 23 2020, 06:08 PM
Got it sorted - this car had aftermarket A/C on it and the original engine is gone. That resulted in the connector for the 12 pin being missing and some funky wiring being where it shouldn't have been.
Got all the misc stiff removed and jumpered to the starter solenoid and the solenoid engages now. Starter isn't spinning despite having 12v there so have other issues to work through still. The lead from the + battery terminal is getting warm to the touch when I try to spin the starter so I may have lots of resistance in that old cabling. I'd like to think the starter is good having just had it rebuilt, but we know how that goes. Going to pull it and bench test it tomorrow. Thanks again for the help! |
Lo-Fi Version | Time is now: 26th April 2024 - 08:41 AM |
