Where should the starter solenoid show up in the engine bay? |
Tdskip |
Sep 23 2020, 07:58 AM
Good morning. Brought the electrical system up on the Fresno 914 - so far so good.
Well, mostly so far so good. My starter solenoid wiring is missing in (in)action. I believe that wiring comes through the tunnel in the cabin but where should it exit the firewall? Once this is sorted I should be able to time it and see if I can get it fired on a temporary fuel tank while the original one is being coated. Thanks! |
GregAmy |
Sep 23 2020, 10:22 AM
Advanced Member Group: Members Posts: 2,302 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
The stock design is for the wire to come from the ignition switch, back through the car harness and into the replay plate via the 14-pin connector pin 1, through the relay plate to the 12-pin connector pin 6 (your diagram), then a yellow wire from there through the rear firewall to the starter solenoid.
Just to clarify, the stock design does not incorporate a separate relay solenoid. So I'm guessing car won't crank? Pull the T12 connector and see if you get 12V when the key is turned to the start position. |
Lo-Fi Version | Time is now: 19th May 2024 - 09:02 AM |
