Installed the new Odyssey battery today,, and was surprised to see how much.... |
Jamie |
Sep 23 2020, 06:55 PM
Senior Member Group: Members Posts: 1,025 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
....smaller the PC925 is than the Optima it replaced. Several of y'all recommended this specific battery, and I had to do some modifications to secure it on the battery tray. It's all charged and ready for a test start and drive tomorrow, and I not completely satisfied with the manner that it is secured in place, but I'll work on that later. (IMG:style_emoticons/default/driving.gif)
Mark Henry |
Sep 23 2020, 07:20 PM
Just make sure it can't move around and nothing sharp is rubbing against the battery. I have seen the hold down saw right through a cell on a loose optima.
Some use some plastic U trim or a short piece of fuel hose slit lengthwise over the hold downs. |
jim_hoyland |
Sep 23 2020, 07:31 PM
Get that VIN ? Group: Members Posts: 9,263 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Pics ? I’d like to see how it fits... (IMG:style_emoticons/default/smile.gif)
Jamie |
Sep 24 2020, 11:19 AM
Here is the new Odyssey I installed yesterday, much smaller that the Optima it replaced. I made wooden blocks to keep the battery from moving laterally, and a steel strap down that I will improve later. The object wrapped in white foam on the top is the trickle charger that stays in place. I'm not pleased with the battery posts because they're too short, and will upgrade when I find suitable replacements. Attached thumbnail(s) |
Sep 24 2020, 11:39 AM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I'm not pleased with the battery posts because they're too short, and will upgrade when I find suitable replacements. I've seen adapters for the short posts a while ago, of course now i can't find them. (IMG:style_emoticons/default/rolleyes.gif) |
jim_hoyland |
Sep 24 2020, 11:43 AM
The battery posts are sketchy; why would they be different from the regular batteries ?
Jamie |
Sep 24 2020, 11:56 AM
The battery posts are sketchy; why would they be different from the regular batteries ? This series of Odysseys come without posts, you have to add screw in posts and what I initially found available were this short.The screw in sockets are recessed below the top of the battery, making full use of the posts problematic. |
jim_hoyland |
Sep 24 2020, 01:27 PM
Will these work ?
https://www.vmaxtanks.com/VCP8-8mm-Stainles...osts-_p_72.html Attached image(s) |
windforfun |
Sep 24 2020, 02:53 PM
Senior Member Group: Members Posts: 1,776 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
What's all the stuff on top?
Mark Henry |
Sep 24 2020, 03:38 PM
Is that as far as it can go down? Is the clamp obstructed?
I have a PC680 it's posts stick a fat 1/8" out of the stock positive clamp and the FLAPS negative cable. But it does have a flat top (side) and I had to take the bolts out and spread the clamps wider to get them down that far. (IMG:http://www.914world.com/bbs2/uploads/post-26-1565064513.jpg) |
rjames |
Sep 24 2020, 03:45 PM
I'm made of metal Group: Members Posts: 3,916 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Odyseey makes SAE terminals for $10. This is what I bought and there's plenty of room to properly seat the cables.
https://www.odysseybattery.com/products/sae-terminal-kit/ |
nditiz1 |
Sep 24 2020, 04:04 PM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
My PC680 came with those terminals. I bought mine from Summit.
@Mark Henry - how much for that PC680 mount? I'd like one for my 6 conversion plz (IMG:style_emoticons/default/biggrin.gif) |
horizontally-opposed |
Sep 24 2020, 04:11 PM
Advanced Member Group: Members Posts: 3,430 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Here is the new Odyssey I installed yesterday, much smaller that the Optima it replaced. I made wooden blocks to keep the battery from moving laterally, and a steel strap down that I will improve later. The object wrapped in white foam on the top is the trickle charger that stays in place. I'm not pleased with the battery posts because they're too short, and will upgrade when I find suitable replacements. Wow. That's a lot smaller. Per Odyssey, looks like it weighs 23.8 pounds. Looks like the Optima I've been using is 39.54 pounds. Mark Henry's PC680 appears to be 15.4 pounds. These are getting pretty attractive, particularly for offsetting some of the weight of a six conversion. |
Montreal914 |
Sep 24 2020, 05:10 PM
Senior Member Group: Members Posts: 1,541 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I didn't use any posts, just connected the eyelet directly on the battery between washers. No problem in over 5 years of use. (IMG:style_emoticons/default/confused24.gif)
Jamie |
Sep 24 2020, 05:33 PM
Threads are way too big. |
Jamie |
Sep 24 2020, 05:38 PM
Odyseey makes SAE terminals for $10. This is what I bought and there's plenty of room to properly seat the cables. https://www.odysseybattery.com/products/sae-terminal-kit/ I looked at these on the Odyssey site, but don't know how they are fastened to the battery? There isn't any info about how they are installed on the battery screw connectors of the PC925. |
nditiz1 |
Sep 24 2020, 06:14 PM
They screw in just like normal terminals
silverg |
Sep 24 2020, 07:55 PM
914s since March 1970 Group: Members Posts: 54 Joined: 7-June 06 From: Winchester, VA Member No.: 6,179 Region Association: MidAtlantic Region |
Mark Henry |
Sep 25 2020, 08:40 AM
My PC680 came with those terminals. I bought mine from Summit. @Mark Henry - how much for that PC680 mount? I'd like one for my 6 conversion plz (IMG:style_emoticons/default/biggrin.gif) It's hand made, if there was a market I'd make them, but I'd need at least 20 to get the price under $100. It's basically 4 sides of an aluminum box and a couple of blocks, it sits on top of and hooks into the OE hold down, then uses the factory hold down bolt. Odyseey makes SAE terminals for $10. This is what I bought and there's plenty of room to properly seat the cables. https://www.odysseybattery.com/products/sae-terminal-kit/ I looked at these on the Odyssey site, but don't know how they are fastened to the battery? There isn't any info about how they are installed on the battery screw connectors of the PC625. I just checked the 680 isn't a flat top, it has the same indents as the 925. I'm using the same terminals as in the the pic, the block on the bottoms gets the terminal bottom flush with the battery top. But note mine are different bolting as they have inset hex socket bolts and I don't remember the terminals being threaded, just the battery. |
Sep 25 2020, 10:29 AM
My PC680 came with those terminals. I bought mine from Summit. @Mark Henry - how much for that PC680 mount? I'd like one for my 6 conversion plz (IMG:style_emoticons/default/biggrin.gif) It's hand made, if there was a market I'd make them, but I'd need at least 20 to get the price under $100. It's basically 4 sides of an aluminum box and a couple of blocks, it sits on top of and hooks into the OE hold down, then uses the factory hold down bolt. Here's #2 of 20 for a PC680 mount if you offer them. It looks super right—period-ish and not overdone, like something Clausecker might have made for the 914-8s. Love it exactly the way it's in your car. |
Lo-Fi Version | Time is now: 26th April 2024 - 06:50 PM |
