Hand Brake Pin, ID please |
74ravenna |
Sep 27 2020, 10:02 AM
Member Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
cary |
Sep 27 2020, 11:06 AM
99916601002 ........... replaced part number, about $4.00. Same as the pin for the other end of the equalizer.
All the usual suspects. It is the pin for the 911 hood shock. |
74ravenna |
Sep 27 2020, 11:38 AM
Thank you Cary.
Sep 27 2020, 01:25 PM
914-6 GT in waiting Group: Members Posts: 19,253 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
PMB Performance carries the different size pins but you have to call.
74ravenna |
Sep 27 2020, 02:40 PM
bdstone914 |
Sep 27 2020, 02:52 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@cary
date='Sep 27 2020, 10:06 AM' post='2854776'] 99916601002 ........... replaced part number, about $4.00. Same as the pin for the other end of the equalizer. All the usual suspects. It is the pin for the 911 hood shock. [/quote] The pin at the equalizer is longer. Maybe PET shows the same number but if hmthe pun at the handle is too long it can scrap on the carpet. |
bdstone914 |
Sep 27 2020, 02:56 PM
@74ravenna
date='Sep 27 2020, 09:02 AM' post='2854756'] I've spent a couple hours looking online at various Vendors for the tiny little retaining pin and clip that holds the Hand Brake Cable to the Hand Brake Lever. My Pin is pretty well beat up and the clip is long gone.....probably vacuumed up! Anyone know where to get these? Photo attached. TIA Steve [/quote] A clutch clevis pin works well and can be removed with the handle in place. Attached thumbnail(s) |
cary |
Sep 27 2020, 03:21 PM
[quote name='bdstone914' date='Sep 27 2020, 01:52 PM' post='2854840']
@cary date='Sep 27 2020, 10:06 AM' post='2854776'] 99916601002 ........... replaced part number, about $4.00. Same as the pin for the other end of the equalizer. All the usual suspects. It is the pin for the 911 hood shock. [/quote] The pin at the equalizer is longer. Maybe PET shows the same number but if hmthe pun at the handle is too long it can scrap on the carpet. [/quote] I'll let you know. I just ordered 10. Not the same, one is an .01 |
Sep 27 2020, 03:33 PM
The early cars didn’t use a spring so they take a shorter pin. The later cars have a longer pin to hold the little arm that holds the spring. The pins are also used on the e-brake cable.
Lo-Fi Version | Time is now: 3rd May 2024 - 04:16 AM |
