Riviera Mags from AutoAtlanta, Anyone have experience with these? |
boxster914 |
Sep 28 2020, 01:33 PM
Member Group: Members Posts: 74 Joined: 17-September 20 From: NC, USA Member No.: 24,700 Region Association: South East States |
I'm considering replacing my steel wheels with the Riviera set from Auto Atlanta:
http://www.autoatlanta.com/Porsche-Riviera...N-R7605530.html Has anyone bought these? Are they good? They seem inexpensive enough to make me wonder versus the Fuchs or other options. I can't find a lot of 4 lug wheels around and the used Pedrini's are expensive and I don't want to get stuck with a warped one. Looking forward to hearing your feedback. |
Mikey914 |
Sep 28 2020, 02:04 PM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
At $520+ each I would not call them inexpensive. I run Riveras on some of my cars, but they are originals. I'm pretty sure you can get originals for 1/2 of that.
The reason they were called Riveras was because they were made by Rivera Porsche here in Portland. I'd hope they are a good reproduction, they are a good look. |
boxster914 |
Sep 28 2020, 02:16 PM
Sorry- wrong link and wrong wheel!
I was referring to the Empi Fuchs set of 4 with lugs and caps $678.96! http://www.autoatlanta.com/Porsche-Empi-Fu...EPI9681KIT.html |
Sep 28 2020, 02:17 PM
914-6 GT in waiting Group: Members Posts: 19,254 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
At $520+ each I would not call them inexpensive. I run Riveras on some of my cars, but they are originals. I'm pretty sure you can get originals for 1/2 of that. The reason they were called Riveras was because they were made by Rivera Porsche here in Portland. I'd hope they are a good reproduction, they are a good look. RIVIERA MAG WHEELS, SET OF FOUR R7605530 - Replacement/Accessory Price: $527.0 @mikey914 (IMG:style_emoticons/default/biggrin.gif) |
dlee6204 |
Sep 28 2020, 02:20 PM
Unless Pendrinis have really taken off in recent times they are usually not too expensive. You should be able to find a good set around 500-700.
I would also not invest in new Riviera's as good used set can be had for 200-300. I would also not buy from AA but that's going down a rabbit hole. |
Sep 28 2020, 02:21 PM
I would up your budget a little and buy real 2.0 four lug Fuchs.
Forged, light, strong, proper offset so it will for a 195/205 tire, unlike empi or rivs. Unlike all the other wheels, Fuchs always go up in value and have a classic look. Pedrinis and Mahles are very soft cast aluminum. Most are bent. It usually takes 3-4 sets to make one good set of wheels. |
Chris914n6 |
Jackstands are my life. Group: Members Posts: 3,309 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
^^ that's a set of 4 Mikey (IMG:style_emoticons/default/slap.gif)
There are lots of 4 lug replicas fuchs, or cookies that look good and are proper offsest. I'm sorry but Rivs = (IMG:style_emoticons/default/icon8.gif) Or drill for 5 lug and get real Porsche wheels.... or fakes. 4 lug cookie 15 or 17 |
brcacti |
Sep 28 2020, 03:28 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Yeah the first wheels were cheaper as was pointed out at a set of 4 for that price not EACH.
dr914@autoatlanta.com |
Sep 28 2020, 03:59 PM
914 Guru Group: Members Posts: 7,832 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
The fuchs have the correct offset for the 914 thankfully as most four on 130 have the vw offset so you cannot wear the widest tire.
These wheels are a good substitute for the factory fuchs as they look very similar but are very inexpensive compared to the real thing. You can strip the black backgroud off of them and make them look very much like the originals. they also are counter drilled to use the factory shorter lug bolts. Although they are cast aluminum unlike the forged magnesium originals, they balance well and look good on the 914. Sorry- wrong link and wrong wheel! I was referring to the Empi Fuchs set of 4 with lugs and caps $678.96! http://www.autoatlanta.com/Porsche-Empi-Fu...EPI9681KIT.html |
Craigers17 |
Sep 28 2020, 04:23 PM
Senior Member Group: Members Posts: 731 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
You seem to be open to wheel options. If that's the case, I have a brand new set of VTO Classic 8's. They are 15x7's, with caps & lugs. PM me if you have any interest. I bought them about 2 months ago for $860 shipped. I'd let them go for $700 if you wanted to pick them up or meet at a halfway point. If not, no worries......just giving you another option. Here's a thread on the wheels:
https://www.google.com/url?sa=t&source=...lvQD1XsruHNoSNd |
Mikey914 |
Sep 28 2020, 05:18 PM
Much better as a set of 4
Personally Cip1 has really good value on wheels too They also have lots of other parts that cross over https://www2.cip1.com/SearchResults.asp?Cat=1934 Lots of selection very inexpensive I like the chrome gas burners Just make sure back spacing is right Attached thumbnail(s) |
Lo-Fi Version | Time is now: 3rd May 2024 - 07:02 PM |
