Help diagnosing braking problem, pedal at floor and e-brake light goes on with braking |
boxster914 |
Oct 2 2020, 08:09 PM
Member Group: Members Posts: 74 Joined: 17-September 20 From: NC, USA Member No.: 24,700 Region Association: South East States |
My brake pedal is at the floor and the e-brake light comes on during braking.
I do have some stopping power but it is much diminished. The rear half of the reservoir was dry so I filled it (the front half was at the line). I pulled the carpet and noticed that the area around the pedal is very wet. I looked under the car and noticed a wet area behind the master cylinder. Should I replace the master cylinder? If so, do you have a recommendation of where to buy it? |
Oct 2 2020, 08:22 PM
914-6 GT in waiting Group: Members Posts: 19,274 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Yes, new MC and rubber lines. PMB Performance.
914Sixer |
Oct 2 2020, 08:50 PM
Light is on because the master cylinder has failed. New 17mm have been NLA for years. Pull your pedal assembly out and rebuild it too. Brake fluid ruins the plastic bearings and eats the paint off everything.
bdstone914 |
Oct 2 2020, 09:01 PM
Attached thumbnail(s) |
boxster914 |
Oct 2 2020, 09:02 PM
is the 914rubber 19mm unit good or is PMB superior in some way?
boxster914 |
Oct 2 2020, 09:03 PM
how much for the new pedal set?
bdstone914 |
Oct 3 2020, 09:45 AM
@boxster914
date='Oct 2 2020, 08:03 PM' post='2856237'] how much for the new pedal set? [/quote] $250 with your core |
mlindner |
Oct 3 2020, 10:56 AM
Senior Member Group: Members Posts: 1,522 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Thats a great price Bruce.
Lo-Fi Version | Time is now: 19th May 2024 - 05:41 AM |
