What's Hiding Under Relay Board, Gremlins You Don't Need |
914Sixer |
Oct 6 2020, 04:43 PM
914 Guru Group: Members Posts: 8,877 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Cleaning up another round of relay boards. This one looked clean but this is what I found. Some of that nasty green stuff that goes after copper.
seanpaulmc |
Oct 6 2020, 07:13 PM
Member Group: Members Posts: 299 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
What do you clean them up with before resealing?
914Sixer |
Oct 7 2020, 06:53 AM
Putty knife, small screw driver and 1 hr of picking, then a bath of lemon juice. Stiff bristle bush to go over the copper tracks with the lemon juice. You may have to go over them several times to clean corrosion.
VaccaRabite |
Oct 8 2020, 10:25 AM
Are you re-potting or pouring in epoxy resin?
Zach |
76-914 |
Oct 8 2020, 10:33 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,496 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Any acid used, even Lemon juice, needs to be neutralized and thouroughly cleaned or the green will return with a vengeance. I wonder what those boards look like from the east coast area?
bob164 |
Oct 8 2020, 10:52 AM
Member Group: Members Posts: 96 Joined: 10-February 18 From: SoCal Member No.: 21,877 Region Association: Southern California |
Whats the best way to neutralize the acid?
73-914 |
Oct 8 2020, 11:01 AM
Senior Member Group: Members Posts: 574 Joined: 24-April 10 From: Albany UpstateNY Member No.: 11,651 Region Association: None |
baking soda
bob164 |
Oct 8 2020, 11:09 AM
Thanks
trojanhorsepower |
Nov 11 2020, 07:25 PM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
So I am working on this now. I have read about people solder the joints before repotting. When I tried I had trouble not melting the plastic around the joint. Also I am having trouble getting the solder to stick. I am pretty familiar with solder in more normal electrical work, but this has me baffled. I have used all the flux I have and nothing seems to help.
Any tips? Thanks Peter |
914Sixer |
Nov 11 2020, 07:45 PM
Not needed in my opinion. I have done close to 100 boards at this point. I have never found a problem with the joint. -6 boards are slightly different in that they did soldier the bottom in 4 places.
trojanhorsepower |
Nov 12 2020, 05:00 PM
Great,
Ill just repot it. Thanks, Peter |
trojanhorsepower |
Nov 12 2020, 06:05 PM
So how bad an idea would it be to bead blast both sides of the board?
Lo-Fi Version | Time is now: 10th May 2024 - 11:37 AM |
