| 1bad914 |
Jul 14 2005, 04:47 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 618 Joined: 6-May 04 From: Battle Creek, MI Member No.: 2,028 |
What dizzy do the V8 guys use, mechanical/vacuum advance, stock or after market. What do you recommend. I have an original HEI with vacuum advance. Motor is an early 1967 327/300 bored .030 over with rebuilt 461 double hump heads, Wieand intake and 750 Holley double pumper.
I'm sure everyone has an opinion, give them to me and I'll wade thru it and make a choice. |
| DBCooper |
Jul 14 2005, 06:03 AM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
I'm putting in an Electromotive crank fire, but only because I don't want to cut the trunk for a distributor to clear. Stick with a vacuum advance unless your cam has so little vacuum signal (>290 degrees) that you have to go mechanical. If you have any reasonable vacuum signal you'll actually never need more than a stock GM HEI unit with good wires. They throw a LOT of spark. are cheap and easy.
| skline |
Jul 14 2005, 06:56 AM
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
I run a Billet GM HEI unit on mine. Got it from Chevrolet Performance. It was around $100.00 and works great.
| neo914-6 |
Jul 14 2005, 07:54 AM
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Bought an aftermarket performance with built in 50k coil HEI on eBay <$100, then a Accel set of HEI plugs which cost almost as much as the HEI...
| marks914 |
Jul 14 2005, 09:05 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
Stock HEI, came with the $300.00 engine.
Mark |
| turbo914v8 |
Jul 15 2005, 12:07 AM
Member ![]() ![]() Group: Members Posts: 373 Joined: 26-July 03 From: Canada Member No.: 952 |
Electromotive all the way. Thats what I am using too.
| dwillouby |
Jul 15 2005, 05:42 AM
Member ![]() ![]() Group: Members Posts: 395 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None
I am using a Mallory Unilite. It has the old style cap that takes up less space. Found it on ebay cheap.
David |
| smrz914 |
Jul 15 2005, 07:38 PM
Soon to be brightening the life of the person behind you. ![]() ![]() Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 |
Accel 60kV coil, MSA 6A box, MSD Billet distributor that connects to the box.
Lo-Fi Version | Time is now: 15th April 2026 - 12:20 PM |
