ahycaramba |
“I live my life a quarter mile at a time.” ![]() ![]() Group: Members Posts: 161 Joined: 17-March 15 From: Murrieta, California Member No.: 18,534 Region Association: Southern California ![]() ![]() |
I know there is a difference in tops from early to late. My questions can the tops be interchangeable if the internal latches and fasteners are swapped? is it only the latches that make them different or is the structural also different?
Thanks in advance. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,970 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I thought I remembered someone saying the windows fit differently but I’m not 100%
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,098 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
I'm curious myself as I've never researched it. And I need to figure out someday which of a couple of tops I have around here are early or late. So this was timely. (IMG:style_emoticons/default/popcorn[1].gif)
mepstein |
I'm curious myself as I've never researched it. And I need to figure out someday which of a couple of tops I have around here are early or late. So this was timely. (IMG:style_emoticons/default/popcorn[1].gif) Early top has a thin rib, late top has a thick one. |
Gint |
Jamie |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,129 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States ![]() ![]() |
I'm curious myself as I've never researched it. And I need to figure out someday which of a couple of tops I have around here are early or late. So this was timely. (IMG:style_emoticons/default/popcorn[1].gif) Early top has a thin rib, late top has a thick one. So what is the time line that delineates between early and late? (IMG:style_emoticons/default/confused24.gif) |
mepstein |
I'm curious myself as I've never researched it. And I need to figure out someday which of a couple of tops I have around here are early or late. So this was timely. (IMG:style_emoticons/default/popcorn[1].gif) Early top has a thin rib, late top has a thick one. So what is the time line that delineates between early and late? (IMG:style_emoticons/default/confused24.gif) If I'm right about the side windows being different, it would start when the newer style window mechanism was added to the doors. Mid '72 I believe. |
altitude411 |
I drove my 6 into a tree ![]() ![]() ![]() Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains ![]() ![]() |
Early vs. late
http://www.914world.com/bbs2/index.php?showtopic=73129 early top doesn't seal well with late doors/windows http://www.914world.com/bbs2/index.php?showtopic=86067 more... http://914world.com/bbs2/index.php?showtopic=329937 I believe early till mid 73 (some 73's manufactured in 72). Build date Jan of 73 had crash bar requirements |
mepstein |
I'm curious myself as I've never researched it. And I need to figure out someday which of a couple of tops I have around here are early or late. So this was timely. (IMG:style_emoticons/default/popcorn[1].gif) Early top has a thin rib, late top has a thick one.Looks like I reversed the rib with - per Paul's thread. |
Gint |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,040 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
@Gint
@mepstein I have a late top that I am going to add the early rubber blocks to and test fit on an early car. The early blocks are shorter and wider. I don't know why they would change that. I don't know it the top web height was changed at the same time.The window seals should not be an issue. 914 rubber list the late seal as better sealing and can be used on the early car for better sealing. Then I am going to test an early top with late blocks on a late car. Will report back her with the findings. The other top differences do not appear to affect fit like the raised bosses on the front latches. @ahycaramba |
bdstone914 |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,445 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
I have a lot of recent experience with this.
The top must be matched to the type of window regulator. If you have early regulators, you have to have an early top. If you have late regulators, you have to have a late top. It has to do with the seals and how they meet up to the top edge of the windows. I know this for fact. My red six conversion (Igor) is a 73, and the top (painted to match the car) is an early top. So the seals don't fit right, and they leak. The top on the Blue 70 914-6 (Elwood) is a late top on an early car. The seals don't quite reach the top edge of the windows. So I added an aluminum strip between the top and the seal mounting track. They actually touch the windows now, but they don't fit right either. I actually took the top of the red car and put it on the blue one. The seals fit fine when I do that, but the car looks really funny... (IMG:style_emoticons/default/biggrin.gif) I have a early top that I am going to get refinished like they did at the factory for the blue six. Also, a 70 914 didn't have a headliner on the underside of the top. Clay |
Gint |
Early vs. late http://www.914world.com/bbs2/index.php?showtopic=73129 early top doesn't seal well with late doors/windows http://www.914world.com/bbs2/index.php?showtopic=86067 more... http://914world.com/bbs2/index.php?showtopic=329937 I believe early till mid 73 (some 73's manufactured in 72). Build date Jan of 73 had crash bar requirements @altitude411 Thanks for finding Paul's posts. And I now realize that the top on my 74 is an early top. The late top was sitting on top of my /6. It looks pretty nice and only needs a couple of tiny paint applications. And a left rear mount. |
Gint |
I know there is a difference in tops from early to late. My questions can the tops be interchangeable if the internal latches and fasteners are swapped? is it only the latches that make them different or is the structural also different? Thanks in advance. @ahycaramba Did this discussion give you the info you were looking for? Questions? @bdstone914 Hey Bruce, Do you have a late left rear targa top mount? This part. Or a set refinished would be great. (IMG:http://www.914world.com/bbs2/uploads/post-4253-1241844925.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-4253-1241844904.jpg) |
Gint |
I did find another targa latch mount, albeit a crusty one with crusty hardware. That late top on a late car makes a lot of difference. I don't have any idea why I did that or when. Probably because of a mount failure (or departure).
ahycaramba |
I don't know about you but I hate when water leaks inside the car. Thanks to all who have tackled this thread. Your help was VERY useful and informative. You all saved me from making a mistake and future headaches. I can't thank you enough. (IMG:style_emoticons/default/beerchug.gif)
Hope to meet up with you guys one day and thank you in person. |
eric9144 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,772 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California ![]() ![]() |
Interesting thread, I've been trying to find a really good 'stock' top to be able to swap out my body colored top just to change up the look if so inclined. I have 3 spare tops now as I've searched for one that needs only paint and minor refinishing vs a full on re-do.
After this thread, realized that I have two early and one late, I need the late one so will be probably bringing the early ones to sell off next time we ever have a G&R Swap meet... Early: ![]() Late: ![]() |
Gint |
As long as we're on the subject...
What is the preferred product to treat a top exterior to freshen it? Even further, if a guy wanted to respray it, what's the DIY solution or product? |
Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,413 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
Post # 146 Link
Here’s how, and the product I used. It turned out nice. Distance when spraying the texture coat, will give you the factory effect as far as texture. Then finish with the black satin used in an earlier post on the same page for the bumpers. ![]() |
Lo-Fi Version | Time is now: 14th July 2025 - 03:51 PM |
