| TX914 |
Oct 12 2020, 01:16 PM
Alan-B ![]() ![]() Group: Members Posts: 177 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None
Anyone have experience with the Reinz oil cooler seals? Are they as good as OEM? The Porsche part is staggeringly more expensive; i.e. $.50 vs. $10.50
Given the oil cooler seals seem to start leaking pretty quickly, extra money might be worth it if OEM is better. |
| Mark Henry |
Oct 12 2020, 01:57 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
For a four or six?
VR seals are fine. I use a dow corning O-ring lube, but I used to install them dry. Are you in a rush and is it for a T4? If not rush (post takes 2 weeks or so) and a T4 PM me your address and I'll send you a couple. |
| TX914 |
Oct 12 2020, 02:02 PM
Mark, thanks for the note. It’s a four (2L). Thanks for the offer but I have some other small bits to order so I’ll just add those and should be here in a couple of days. I’m dropping the engine tommorrow.
Cheers, Alan |
| Big Len |
Oct 12 2020, 04:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
Changed mine last year to Reinz. All good.
| Ian Stott |
Oct 13 2020, 06:05 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
For a four or six? VR seals are fine. I use a dow corning O-ring lube, but I used to install them dry. Are you in a rush and is it for a T4? If not rush (post takes 2 weeks or so) and a T4 PM me your address and I'll send you a couple. Hey Mark, can we set up a phone conversation with my Belgian mechanic and you, we are going to install the SDS fuel injection system. You may have some things we need and we can make a deal for the Ljet you installed a while back. Plus you may have other things I may need, I think I need a later top as my windows do not seal well, etc. Ian |
Lo-Fi Version | Time is now: 12th March 2026 - 06:08 AM |
