Paint protection film? |
mb911 |
Oct 12 2020, 05:49 PM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Slightly OT but need some advice.. We have too many of the kids cars at the house for the winter(actually all the time) we are trying to spend as little money as possible right now for many reasons(hence selling all my stashed items ).. So the question.. My sons 944 sunroof leaks a bit and I don't want the interior trashed. A all weather car cover for the car to be outside is out (my wife thinks it looks trashy) so thinking a clear square of self adhesive film to cover the sunroof might be a great option? Any thoughts or experience.. Yes sunroof has new seal and it still leaks.. Not idea why..
Let me know what you think might work. |
Jett |
Oct 12 2020, 06:35 PM
Senior Member Group: Members Posts: 1,638 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Slightly OT but need some advice.. We have too many of the kids cars at the house for the winter(actually all the time) we are trying to spend as little money as possible right now for many reasons(hence selling all my stashed items ).. So the question.. My sons 944 sunroof leaks a bit and I don't want the interior trashed. A all weather car cover for the car to be outside is out (my wife thinks it looks trashy) so thinking a clear square of self adhesive film to cover the sunroof might be a great option? Any thoughts or experience.. Yes sunroof has new seal and it still leaks.. Not idea why.. Let me know what you think might work. An adhesive plastic film will work, or remove the headliner and root cause the leak. Or you can try a hybrid tape, like : https://www.amazon.com/Vapor-Barrier-Seam-T...9261&sr=8-4 |
mb911 |
Oct 12 2020, 06:39 PM
Slightly OT but need some advice.. We have too many of the kids cars at the house for the winter(actually all the time) we are trying to spend as little money as possible right now for many reasons(hence selling all my stashed items ).. So the question.. My sons 944 sunroof leaks a bit and I don't want the interior trashed. A all weather car cover for the car to be outside is out (my wife thinks it looks trashy) so thinking a clear square of self adhesive film to cover the sunroof might be a great option? Any thoughts or experience.. Yes sunroof has new seal and it still leaks.. Not idea why.. Let me know what you think might work. An adhesive plastic film will work, or remove the headliner and root cause the leak. Or you can try a hybrid tape, like : https://www.amazon.com/Vapor-Barrier-Seam-T...9261&sr=8-4 The headliner is out and still can't figure out where.. Will check this out though. Thanks |
Superhawk996 |
Oct 13 2020, 06:39 AM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
The headliner is out and still can't figure out where.. Will check this out though. Thanks @mb911 I have experience root causing water leaks during water test in assembly plants. You can get a a great deal of water though the tiniest pin hole and/or weld seam that wasn't sealed properly. Some can be very hard to find when they are tiny. If dealing with a sunroof, I'll assume you've already verified the sunroof drain tubes aren't plugged. Usual prcedure to root cause is the use negative pressure and a smoke pencil. Very similar to finding leaks in home construction etc. You're a pretty creative guy so I'll assume you can work out the details. You can use a venturi vacuum generator and/or old blower fan to create negative pressure inside cabin. Need to seal air bag louvers, HVAC intake, tape windows, etc. unless you have a large enough airflow source to overcome more than about 200 CFM of leakage though normal leak sources. You can buy or make a smoke machine on the cheap - see YouTube (think haloween fog machine) or professional smoke pencil. The smoke will permeate even the smallest crack between sheet metal flanges or tiny gaps in windshield sealnts, sunroof adhesives, etc. Good Luck, sometimes they are a real challenge. |
Cairo94507 |
Oct 13 2020, 07:06 AM
Michael Group: Members Posts: 9,759 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Hey Ben - You might want to look into what bodyshops call crash wrap. It is easy to install and sticks quite well. Before Chris @Tygaboy hooked me up with a trailer to bring my car home, I had a flat/open trailer lined up and we were just going to crash wrap my car and haul it. Ended up going enclosed so we did not do the crash wrap. It works and will stay in place for the whole winter however I think I would not leave it on that long. Might be a pain to remove. Absent that, clear bra PPF should be great but might be more costly to do. (IMG:style_emoticons/default/beerchug.gif)
mb911 |
Oct 13 2020, 07:23 AM
Thanks guys I am not sure I will spend much time on it but good suggestions.. With all the craziness in my life right now just trying to do the minimum on his car.
FlacaProductions |
Oct 13 2020, 08:50 AM
Senior Member Group: Members Posts: 1,588 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
DRPHIL914 |
Oct 13 2020, 09:17 AM
i did this with the sun roof on my wife's jaguar. on a heavy rain the drain tubes just cant take all the water and it ends up coming down the pillar and into the driver side rear floor pan , so until the line gets cleaned out or fixed, it could be detached too, i put a sheet of clear PPF over the whole thing . you can buy smaller sheets from a dealer or on Ebay.
in a pinch you can go to home depot and get the clear adhesive plastic roll used during construction to protect carpet or flooring that has been placed down but construction is going on they put it down and pull it up . you can use that but it does not come up as easy, and UV breaks it down so use for short term only. it is hard to remove and get the adhesive off the paint. |
BillC |
Oct 13 2020, 09:20 AM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Check your drain tubes. The sunroof seals aren't completely waterproof (and aren't intended to be), and you'll get leaks into the car if the drain tubes are clogged.
Lo-Fi Version | Time is now: 17th May 2024 - 05:33 PM |
