over-pressurized case |
Joe Ricard |
Jul 14 2005, 10:34 AM
He's got to come get it 1st. Won't be long now ..... In this order. High oil level results in high oil pressure which leads to blowing out seals at crank or cooler. Maybe even the case plugs behind the flywheel. All of a sudden the green light goes on as a result of no oil pressure. Hence you now need my motor REAL BAD. Nobody but me puts a wrench on my car. Some people I don't even open the engine lid to look inside. |
Allan |
Jul 14 2005, 10:36 AM
Does this have anything to do with "How do I change oil cooler seals"?
bd1308 |
Jul 14 2005, 10:37 AM
i'm not measuring....it's pretty obvious. Joe the guy with the truck i will talk to today. |
Mueller |
FYI,
real race engines will have vac. pumps installed to minimize the crankcase pressure, some work so well that you could have a 1" hole in the side of the case and not lose oil while the motor was running.... bottom line, do you have a vent hose to atmosphere for the crankcase? |
bd1308 |
Jul 14 2005, 10:38 AM
nope...wasnt it. twas the pressure switch. |
bondo |
Jul 14 2005, 10:43 AM
I beg to differ. Oil level is unrelated to oil pressure. Oil pressure is regulated by the spring and piston arrangement in the case. The crankcase is simply a reservoir to pump oil from. It can be as high as you like as long as it doesn't hit moving parts. Once it does it becomes a low oil pressure problem. Crankcase pressure is regulated by blowby and venting. I think it's time for a leakdown test. Oil level is clearly not the problem here. |
bd1308 |
Jul 14 2005, 10:44 AM
right now i made a hose system to vent both heads and the PCV to the fitting to the carb with a T fitting. seemed to work fine when the pressure switch was pouring oil all over the place.... but now taht i have the switch fixed other problems are creeping up. ran liek a charm until i stopped to get oil. |
bd1308 |
Jul 14 2005, 10:45 AM
i really hate venting to atmosphere.....
motor honey wont fix the prob for now.... |
Mueller |
Jul 14 2005, 10:53 AM
is the air from the crankcase going into the intake before or after the carb?? |
bd1308 |
Jul 14 2005, 11:02 AM
before..... i dont know how to make it after.....but i figure there is more vac that way |
gklinger |
Jul 14 2005, 11:17 AM
doh! Group: Members Posts: 316 Joined: 14-January 03 From: Tempe, AZ Member No.: 146 Region Association: Southwest Region |
IIRC the head vents are *intake* for fresh air into the crankcase, not *exhaust*. The PCV valve is the crankcase exhaust. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Joe Ricard |
Jul 14 2005, 11:25 AM
Sorry I don't know what I was thinking. Maybe I don't know shit about effects of high oil level because I never experienced it. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Yea yea that's it. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) |
Rouser |
Jul 14 2005, 04:09 PM
Anti-Post Whore Group: Benefactors Posts: 597 Joined: 30-December 02 From: Citrus Park, Florida Member No.: 54 |
Lose the PCV valve; it's not doing anything but constipating the crankcase. You're not set up (anymore) to utilize a PCV valve, and if you're not running a breather box arrangement, than THAT'S your problem. I'm sure your VW "mechanic" knew that, right? One hose to each head vent tube, and one hose to the aforementioned "REMOVED" PCV port (for oil drain back). Do NOT use the plastic-crap hose you receive with the unit; it's garbage and it cracks IMMEDIATELY. The box internally vents to atmosphere (ahh, shucks), which means you'll have a trail of enviro-nazis chasing you around town. The price you pay for going to carbs. And you thought carbs could fix anything. |
74914LE |
Jul 14 2005, 05:38 PM
Member Group: Members Posts: 136 Joined: 6-April 04 From: Fort Worth, TX Member No.: 1,895 |
The topic caught my attention, because I once had the same issue.
Oil was blowing out of the crankcase, very much like you are describing. I tried everything to solve the problem. Breathers, checking pressure, and then the loud tapping started. It turned out that the #3 Exhaust Valve Guide had come loose. The Exhaust Valve was not seating properly, which caused the case to get pressure back through the push rod tubes, is the theory I came up with. You can check this by looking at the Valve Adjustment screws, as they will get hammered as the exhaust valve moves more freely in the guide. Eventually, the Valve Seat area will start to loose some aluminum, which will show up as a nice silver paste. When I pulled the head, the valve could be moved around in the new larger seat that the excess play had caused. Fixed the problem by replacing the head. My issue was with a 1.7lt. head, but it should not matter. |
bd1308 |
Jul 14 2005, 06:00 PM
enviro-nazis?? they dont exist anymore in KY...
Rouser |
Jul 14 2005, 06:11 PM
Unless your state lit a bonfire and can show me the charred remains, they're breediing in every college campus across the country. Some are easier to deal with than others. |
bd1308 |
Jul 14 2005, 06:15 PM
what are you on? no emissions testing=no enviro-nazis
you should see some of the cars on the road here.... |
Mueller |
Jul 14 2005, 06:17 PM
NOT YET !!!!!! every state is slowly "catching" up to CA...if the US gov. starts to mandate cleaner air, they'll force the states to clean up....it's only a matter of time.... |
bd1308 |
Jul 14 2005, 06:18 PM
a year ago, my county DROPPED emissions "smog" testing.......
other counties in KY have *never* heard of smog testing. |
bd1308 |
Jul 14 2005, 06:19 PM
besides its a 74--rolling exemption....
and by that time i'll have a real engine.... |
Lo-Fi Version | Time is now: 5th June 2024 - 10:17 AM |
