Trans question for the brain trust |
BPic |
Oct 17 2020, 01:15 PM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
My trans goes into all gears but pops out of 2nd. I don't know if it pops out of 4th as I haven't gotten that fast. 3rd 1st and reverse are no issues.
The other thing is I can actually push past 2nd and 4th, with car off and without much effort, and then this happens... (IMG:style_emoticons/default/headbang.gif) I can drive it in 2nd if I hold the shifter in place. I've adjusted again and again using all the techniques and it doesn't appear to change even the slightest. Is there something I'm missing or is it time for a rebuild. (IMG:style_emoticons/default/barf.gif) |
porschetub |
Oct 17 2020, 01:44 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
My trans goes into all gears but pops out of 2nd. I don't know if it pops out of 4th as I haven't gotten that fast. 3rd 1st and reverse are no issues. The other thing is I can actually push past 2nd and 4th, with car off and without much effort, and then this happens... (IMG:style_emoticons/default/headbang.gif) I can drive it in 2nd if I hold the shifter in place. I've adjusted again and again using all the techniques and it doesn't appear to change even the slightest. Is there something I'm missing or is it time for a rebuild. (IMG:style_emoticons/default/barf.gif) You have the wrong part that holds the nylon ball cup,believe you have the shorter one,I would think all will come good when you change it . Good luck. |
BPic |
Oct 17 2020, 01:47 PM
My trans goes into all gears but pops out of 2nd. I don't know if it pops out of 4th as I haven't gotten that fast. 3rd 1st and reverse are no issues. The other thing is I can actually push past 2nd and 4th, with car off and without much effort, and then this happens... (IMG:style_emoticons/default/headbang.gif) I can drive it in 2nd if I hold the shifter in place. I've adjusted again and again using all the techniques and it doesn't appear to change even the slightest. Is there something I'm missing or is it time for a rebuild. (IMG:style_emoticons/default/barf.gif) You have the wrong part that holds the nylon ball cup,believe you have the shorter one,I would think all will come good when you change it . Good luck. There's more than one size of those cast cups? I have 2 from 2 different transmissions and both the same. I'll start looking now. Thanks. |
porschetub |
Oct 17 2020, 02:34 PM
My trans goes into all gears but pops out of 2nd. I don't know if it pops out of 4th as I haven't gotten that fast. 3rd 1st and reverse are no issues. The other thing is I can actually push past 2nd and 4th, with car off and without much effort, and then this happens... (IMG:style_emoticons/default/headbang.gif) I can drive it in 2nd if I hold the shifter in place. I've adjusted again and again using all the techniques and it doesn't appear to change even the slightest. Is there something I'm missing or is it time for a rebuild. (IMG:style_emoticons/default/barf.gif) You have the wrong part that holds the nylon ball cup,believe you have the shorter one,I would think all will come good when you change it . Good luck. There's more than one size of those cast cups? I have 2 from 2 different transmissions and both the same. I'll start looking now. Thanks. No problem,I would measure mine for you but my car is off the jackstands for a change (IMG:style_emoticons/default/av-943.gif) . |
Lo-Fi Version | Time is now: 2nd May 2024 - 07:19 AM |
