Trans question for the brain trust |
BPic |
Oct 17 2020, 01:15 PM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
My trans goes into all gears but pops out of 2nd. I don't know if it pops out of 4th as I haven't gotten that fast. 3rd 1st and reverse are no issues.
The other thing is I can actually push past 2nd and 4th, with car off and without much effort, and then this happens... (IMG:style_emoticons/default/headbang.gif) I can drive it in 2nd if I hold the shifter in place. I've adjusted again and again using all the techniques and it doesn't appear to change even the slightest. Is there something I'm missing or is it time for a rebuild. (IMG:style_emoticons/default/barf.gif) |
BPic |
Oct 17 2020, 02:13 PM
I measured mine and both are 65 mm. Anyone know where to get a longer one?
dr914@autoatlanta.com |
Oct 17 2020, 02:43 PM
914 Guru Group: Members Posts: 7,827 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
that shift head looks correct, have you installed a better ball cup bushing? On the other hand, maybe someone at one time cut yours shorter for 911 and early 914 applications. The first thing I thought is that someone installed the earlier shift head in your car until I saw a picture of it
I measured mine and both are 65 mm. Anyone know where to get a longer one? |
BPic |
Oct 17 2020, 02:48 PM
that shift head looks correct, have you installed a better ball cup bushing? On the other hand, maybe someone at one time cut yours shorter for 911 and early 914 applications. The first thing I thought is that someone installed the earlier shift head in your car until I saw a picture of it I measured mine and both are 65 mm. Anyone know where to get a longer one? Thanks Dr. No the head was not altered. I have two that are identical. |
Lo-Fi Version | Time is now: 2nd May 2024 - 01:30 AM |
