Trans question for the brain trust |
BPic |
Oct 17 2020, 01:15 PM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
My trans goes into all gears but pops out of 2nd. I don't know if it pops out of 4th as I haven't gotten that fast. 3rd 1st and reverse are no issues.
The other thing is I can actually push past 2nd and 4th, with car off and without much effort, and then this happens... (IMG:style_emoticons/default/headbang.gif) I can drive it in 2nd if I hold the shifter in place. I've adjusted again and again using all the techniques and it doesn't appear to change even the slightest. Is there something I'm missing or is it time for a rebuild. (IMG:style_emoticons/default/barf.gif) |
Rich Bontempi |
Oct 17 2020, 02:39 PM
914 Road Racer Group: Members Posts: 167 Joined: 5-February 03 From: Redwood City Ca. 94063 Member No.: 239 Region Association: Northern California |
My trans goes into all gears but pops out of 2nd. I don't know if it pops out of 4th as I haven't gotten that fast. 3rd 1st and reverse are no issues. The other thing is I can actually push past 2nd and 4th, with car off and without much effort, and then this happens... (IMG:style_emoticons/default/headbang.gif) I can drive it in 2nd if I hold the shifter in place. I've adjusted again and again using all the techniques and it doesn't appear to change even the slightest. Is there something I'm missing or is it time for a rebuild. (IMG:style_emoticons/default/barf.gif) I'm looking at your pic, and I can't see the washer that goes on both sides of the shift housing and the lever. There should be one washer on both sides of the shift housing. We stock them, if they aren't there. Rich |
BPic |
Oct 17 2020, 02:46 PM
My trans goes into all gears but pops out of 2nd. I don't know if it pops out of 4th as I haven't gotten that fast. 3rd 1st and reverse are no issues. The other thing is I can actually push past 2nd and 4th, with car off and without much effort, and then this happens... (IMG:style_emoticons/default/headbang.gif) I can drive it in 2nd if I hold the shifter in place. I've adjusted again and again using all the techniques and it doesn't appear to change even the slightest. Is there something I'm missing or is it time for a rebuild. (IMG:style_emoticons/default/barf.gif) I'm looking at your pic, and I can't see the washer that goes on both sides of the shift housing and the lever. There should be one washer on both sides of the shift housing. We stock them, if they aren't there. Rich Rich do you mena the highlighted washer? I'll check. |
Rich Bontempi |
Oct 17 2020, 02:50 PM
My trans goes into all gears but pops out of 2nd. I don't know if it pops out of 4th as I haven't gotten that fast. 3rd 1st and reverse are no issues. The other thing is I can actually push past 2nd and 4th, with car off and without much effort, and then this happens... (IMG:style_emoticons/default/headbang.gif) I can drive it in 2nd if I hold the shifter in place. I've adjusted again and again using all the techniques and it doesn't appear to change even the slightest. Is there something I'm missing or is it time for a rebuild. (IMG:style_emoticons/default/barf.gif) I'm looking at your pic, and I can't see the washer that goes on both sides of the shift housing and the lever. There should be one washer on both sides of the shift housing. We stock them, if they aren't there. Rich Rich do you mena the highlighted washer? I'll check. Number 15 and number 18 are the washers! |
Lo-Fi Version | Time is now: 3rd May 2024 - 11:09 AM |
