Clutch cable wheel protection...?, Hate to leave my new beautiful cable and wheel exposed,,,, |
second wind |
Oct 17 2020, 07:48 PM
Senior Member Group: Members Posts: 850 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
I have tried covering my clutch cable wheel and cable several different ways but nothing great....just changed my cable and it seems a shame to leave it out in the open like it is.....any good ideas to keep the road grit out? I think Mikey should be working on this but who am to say? Welcome ideas and it just makes sense to protect this vital area from contamination.....thank you for your thoughts,,,,
gg |
HansJan |
Oct 17 2020, 07:57 PM
Member Group: Members Posts: 394 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
I have tried covering my clutch cable wheel and cable several different ways but nothing great....just changed my cable and it seems a shame to leave it out in the open like it is.....any good ideas to keep the road grit out? I think Mikey should be working on this but who am to say? Welcome ideas and it just makes sense to protect this vital area from contamination.....thank you for your thoughts,,,, gg This is what I installed. Still get dirty (but maybe a little less). Better ground clearance for sure. http://www.tangerineracing.com/transmission.htm |
second wind |
Oct 17 2020, 08:06 PM
I have tried covering my clutch cable wheel and cable several different ways but nothing great....just changed my cable and it seems a shame to leave it out in the open like it is.....any good ideas to keep the road grit out? I think Mikey should be working on this but who am to say? Welcome ideas and it just makes sense to protect this vital area from contamination.....thank you for your thoughts,,,, gg This is what I installed. Still get dirty (but maybe a little less). Better ground clearance for sure. http://www.tangerineracing.com/transmission.htm Come on....how about a remedy? gg |
porschetub |
Oct 17 2020, 10:34 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I have tried covering my clutch cable wheel and cable several different ways but nothing great....just changed my cable and it seems a shame to leave it out in the open like it is.....any good ideas to keep the road grit out? I think Mikey should be working on this but who am to say? Welcome ideas and it just makes sense to protect this vital area from contamination.....thank you for your thoughts,,,, gg I bought a CSOB cable and it was rubbish,I had already bought the 914rubber delron roller and its a great part,but after fitting the original cable with proper nylon liner had a huge improvement in pedal feel so don't buy the cheap cable (IMG:style_emoticons/default/headbang.gif) . IMO make sure you have the rubber boot on the cable and don't use any lube ,stock mounting is fine for road grime even without the plastic cover which I have back on now,however if you have the horizontal TR setup you may pick a bit more grime up but is no cover to fit that. |
Maltese Falcon |
Oct 17 2020, 11:18 PM
Advanced Member Group: Members Posts: 4,634 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Superhawk996 |
Oct 18 2020, 07:35 AM
914 Guru Group: Members Posts: 5,749 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Always envious of you guys that have cars that have so few problems that you have time to invent new problems to be solved. (IMG:style_emoticons/default/rolleyes.gif)
914Sixer |
Oct 18 2020, 11:03 AM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Another option is from Tangerine Racing mount $52.
Attached image(s) |
jim_hoyland |
Oct 18 2020, 04:20 PM
Get that VIN ? Group: Members Posts: 9,262 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I’ve had the same thought. My clutch cable seems to break at the wheel. I think it’s because the grease and sand abrade the wires as the tranny is shifted.
second wind |
Oct 18 2020, 05:09 PM
I have been told by a 914 expert that the cable ALWAYS breaks at the wheel. Allowing dirt and grime into the roller area and cable/roller contact area just does't make sense to us wear avoidance folks....gotta' be a way with a plastic bubble or something.....I have been using baggies and magnets....not great....there has got to be a solution....thank you,
gg |
porschetub |
Oct 18 2020, 05:18 PM
Yes that was kinda my point about horizontal rollers,the road grime with collect in that area and has no where to go, the stock roller mount will collect less if you don't use grease and reduce cable wear @ that point because that's the weak point due to a fairly tight radius ,the delron roller (914rubber) is a great update as the stock nylon one wears out @ the centre bush and loads the action further...as my old one did.
(IMG:style_emoticons/default/beer.gif) |
Superhawk996 |
Oct 18 2020, 06:00 PM
Yes that was kinda my point about horizontal rollers,the road grime with collect in that area and has no where to go, the stock roller mount will collect less if you don't use grease . . . (IMG:style_emoticons/default/agree.gif) Horizontal makes sense on a race car that has been severely lowered to aid ground clearnace. Not an issue on cars at or near stock ride height. No grease on cable. A dab of grease at the wheel center pivot. Wheel needs to rotate. If you're repeatedly breaking cables -- make sure you have a zero ohm ground connection between body and engine/trans. Otherwise the clutch cable becomes the ground and drastically shortens cable life. |
Mikey914 |
Oct 19 2020, 09:04 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have had this problem. It starts to stretch then breaks.
second wind |
Oct 19 2020, 10:12 PM
Ok....I am hatching an idea here.....I took a close look at the clutch wheel area today and there is enough room for the little tiny magnets that Harbor Frieght sells all around the wheel...these are rare earth magnets and very strong...so if I put a womens nylon around the wheel and attach with these little magnets I may have a fine screen to help protect the cable and such. Can anyone suggest a better screen material than a woman's nylon? I am thinking 99 cent store for the nylon....Harbor Frieght magnets are $3 tops....I am not giving up on this until my new cable and wheel are protected so hang on......thank you for any input...
gg |
altitude411 |
Oct 19 2020, 10:45 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
yeah, um.... (IMG:style_emoticons/default/smoke.gif) no |
Olympic 914 |
Oct 20 2020, 07:01 AM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
If you really need a project, rig up a hydraulic clutch.
No cable to break.. |
GregAmy |
Oct 20 2020, 07:37 AM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Always envious of you guys that have cars that have so few problems that you have time to invent new problems to be solved. (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/biggrin.gif) What are we talking about? 10-yr lifespan for a clutch cable? Even if it's 5 - and I'd find that very hard to believe - it's neither an expensive nor hateful replacement job. And this will not resolve cable stretching, of course, which is a far more-common problem. Chris designed the horizontal wheel bracket for clearance around his headers. It's not intended for any kind of "safety" or lifespan problems. |
Spoke |
Oct 20 2020, 08:43 AM
Jerry Group: Members Posts: 6,976 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
.....any good ideas to keep the road grit out? I printed a cover a while back but didn't mount it. I tried some clips but they didn't hold it on. Probably should have just used some tiewraps. Here's what it looks like now. Attached thumbnail(s) |
second wind |
Oct 20 2020, 12:07 PM
Wow....those last two replies really are thought provoking. Just how significant is the dirt contamination in the life of a cable? Great question....And then the picture of the actual cover is amazing.....I want one of those!! Especially if it was made out of clear plastic or softer clear rubber (hint hint Mark). Anyway.....I am on my way to the fabric store to buy some polyester cloth and see what I can come up with. Thanks you guys,
gg |
Superhawk996 |
Oct 20 2020, 05:30 PM
.....any good ideas to keep the road grit out? I printed a cover a while back but didn't mount it. I tried some clips but they didn't hold it on. Probably should have just used some tiewraps. Here's what it looks like now. As much as I think it's a solution seeking a problem, that is great design work and you have at least one interested customer! Great job! I wish I had more time to play . . . Is that done in Inventor? Axis and the way planes are notated look familiar. Maybe some other AutoDesk product? |
Villemi |
Feb 7 2021, 01:02 PM
Newbie Group: Members Posts: 48 Joined: 7-January 20 From: France Member No.: 23,807 Region Association: France |
Hello
When can I find this 3D file of this wheel clutch cover? |
Lo-Fi Version | Time is now: 26th April 2024 - 12:47 PM |
