Rear Rubber Bumper Top, Question re center stud.... |
jim_hoyland |
Oct 18 2020, 04:14 PM
Get that VIN ? Group: Members Posts: 9,273 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The rubber top fits nicely; but it appears there is an extra stud in the center with no hole to go through. What am I missing here ? Should the stud be capped ?
@Mikey914 Attached thumbnail(s) Attached image(s) |
JeffBowlsby |
Oct 18 2020, 08:40 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The license plate lights mounting screws penetrate that steel reinf in the bumper top. One of the two screws for each light is a ground screw. That tab on the 70-74 chassis provides grounding for the lights. If the lights are not hooked up correctly you’ll blow fuses due to a direct short of the lights power circuit to ground.
Lo-Fi Version | Time is now: 6th May 2024 - 02:55 PM |
