Rear Sail Trim Installation, How to Install Rear Sail Trim? |
MFejsa |
Oct 20 2020, 04:11 AM
Newbie Group: Members Posts: 40 Joined: 25-April 20 From: Saudi Arabia Member No.: 24,178 Region Association: None |
Hi, can anyone explain how to install rear sail trims? Having trouble with the roll bar clip lining up with the hole on the car. thanks
DRPHIL914 |
Oct 20 2020, 06:25 AM
do you mean the horizontal piece or the side vertical piece?
for the side vertical piece it helps to have the bottom clip that is bolted down from underside , loosen that bolt by accessing the wheel well, helps to take the wheel off, as you slide it on the clip be careful not to scratch paint. as you get it forward enough as you get the top in line and slid over the end of the horizontal piece that should already be in place , the hole should line up but it may help to use a wire to find the hole and line it up before then getting the screw installed. good luck, post some pictures too! |
DRPHIL914 |
Oct 20 2020, 06:26 AM
forgot to add—
(IMG:style_emoticons/default/welcome.png) |
Robarabian |
Oct 20 2020, 08:21 AM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
Sorry. I thought meant vinyl. DRPHIL914 describes it.
MFejsa |
Oct 21 2020, 12:31 AM
Appreciate the advice. Its the vertical piece. The difficult is lining up the trim with the fixed piece that is bolts to the car. The piece seems to be smaller than the trim and moves around quite a bit. Might need to mask up the paint so i dont damage the paint. Will send through some pics as well before and after. Thanks again
DRPHIL914 |
Oct 21 2020, 06:53 AM
Appreciate the advice. Its the vertical piece. The difficult is lining up the trim with the fixed piece that is bolts to the car. The piece seems to be smaller than the trim and moves around quite a bit. Might need to mask up the paint so i dont damage the paint. Will send through some pics as well before and after. Thanks again for sure it can scratch under that trim so tape it up , and disconnect that piece from underside so that its loose and you can get the trim slid over it easier, and it will be tighter as it slides back further on, then as you get the top and bottom lined up , you can pull it down tight by putting the nut and washer on the underside in the fender well, pulling it down tight to the body. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:24 PM |
