QUOTE(MFejsa @ Oct 21 2020, 02:31 AM)
Appreciate the advice. Its the vertical piece. The difficult is lining up the trim with the fixed piece that is bolts to the car. The piece seems to be smaller than the trim and moves around quite a bit. Might need to mask up the paint so i dont damage the paint. Will send through some pics as well before and after. Thanks again
for sure it can scratch under that trim so tape it up , and disconnect that piece from underside so that its loose and you can get the trim slid over it easier, and it will be tighter as it slides back further on, then as you get the top and bottom lined up , you can pull it down tight by putting the nut and washer on the underside in the fender well, pulling it down tight to the body.
