FS Renegade LS conversion stuff |
speed metal army |
Oct 21 2020, 02:07 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
I have all the RH goodies for an LS swap. Engine bar, electric WP, adapter plate, clutch/flywheel and full radiator setup . Also all the engine conversion bits, alt bracket, cooling plates etc. Probably 2000 miles tops on all the stuff, I just dont drive as much as I would like to. I also have the super slim oil pan that gives max clearance when running this set up, and the trans mounts too. Worked flawlessly, the RH stuff is proven.
RH-$4500 Speed Metal-$2600 No, I dont want to sell any of it piecemeal. Thanks, |
dakotaewing |
Oct 22 2020, 09:31 AM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
I have all the RH goodies for an LS swap. Engine bar, electric WP, adapter plate, clutch/flywheel and full radiator setup . Also all the engine conversion bits, alt bracket, cooling plates etc. Probably 2000 miles tops on all the stuff, I just dont drive as much as I would like to. I also have the super slim oil pan that gives max clearance when running this set up, and the trans mounts too. Worked flawlessly, the RH stuff is proven. RH-$4500 Speed Metal-$2600 No, I don't want to sell any of it piecemeal. Thanks, What's the story on the motor you were using with this set up? Which trans mount? |
Lo-Fi Version | Time is now: 12th May 2024 - 02:03 AM |
