ADDCO Rear Bar |
ADDCO Rear Bar |
yeahmag |
Oct 22 2020, 10:23 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Does anyone have experience with the ADDCO 974 rear swaybar? Pricing is good and it seems like I could adapt it to mount to the shock bolts with minimal effort.
Mark Henry |
Oct 22 2020, 11:54 AM
I have real old one kicking around somewhere, IIRC it really sucked (attachment) compared to a stock bar.
yeahmag |
Oct 22 2020, 12:06 PM
Yeah. The default attachment method appears to be drilling a hole through the trailling arm in front of the "axle hole" and through bolting it.
Chris914n6 |
Oct 22 2020, 01:45 PM
Jackstands are my life. Group: Members Posts: 3,316 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Moving the attachment point will make it stiffer.
But really, it's not a good design thus it never became common. |
carr914 |
Oct 23 2020, 04:35 AM
Racer from Birth Group: Members Posts: 118,448 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I know the Owner of ADDCO personally
Find a Better Bar |
Tdskip |
Oct 23 2020, 06:18 AM
To be fair I have not tried any of their products on a 914, but have used them for our applications and they just never seem to fit right.
maf914 |
Oct 23 2020, 03:53 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I put a pair of ADDCO sway bars on my old 1992 Nissan pickup (back when imported pickups were small) along with some Tokico shocks. Not bad. They really tightened up the handling. Don't know anything about their 914 bars.
914Toy |
Oct 23 2020, 07:50 PM
Senior Member Group: Members Posts: 717 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
If you are not going to track/auto cross your car, some of us believe you do not need a rear anti sway bar.
yeahmag |
Oct 23 2020, 08:08 PM
Oh I’m way out in left field here. I will be running over twice the normal autocross spring rate on the rear and am considering a rear sway bar to be able to back that down a bit. At the very least a tuning device.
If anyone in SoCal has a bar I can test with and potentially buy, let me know. |
sixnotfour |
Oct 24 2020, 02:53 AM
914 Wizard Group: Members Posts: 10,422 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
addco on my dads 914 used a piece of angle iron on shock bolt .
Johny Blackstain |
Oct 24 2020, 06:25 AM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
I'm quite satisfied with my rear Addco, however it's bolted to a Eaton limited slip with 3/4 ton springs & air shocks... (IMG:style_emoticons/default/biggrin.gif)
Attached thumbnail(s) |
Tdskip |
Oct 24 2020, 07:04 AM
I'm quite satisfied with my rear Addco, however it's bolted to a Eaton limited slip with 3/4 ton springs & air shocks... (IMG:style_emoticons/default/biggrin.gif) Ha! |
maf914 |
Oct 27 2020, 05:39 PM
I know the Owner of ADDCO personally - Lying Ass Ed is what I call him Find a Better Bar (IMG:style_emoticons/default/av-943.gif) Wow! |
Chris914n6 |
Oct 27 2020, 07:27 PM
Don't have my notes handy, but the stock rear bar calculated out to only around 30 lbs/in. Significant on a 110lb stock spring but not so much at double...
Depending on your front bar you might want to go for the adjustable race spec version from whoever is making them these days. Oh I’m way out in left field here. I will be running over twice the normal autocross spring rate on the rear and am considering a rear sway bar to be able to back that down a bit. At the very least a tuning device. If anyone in SoCal has a bar I can test with and potentially buy, let me know. |
Lo-Fi Version | Time is now: 7th May 2024 - 08:22 AM |
