Oil Level Question |
Ansbacher |
Oct 22 2020, 11:59 AM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
It seems with my car ('74 2.0L dual carbs) I must let the car sit for at least 12 hours to get an accurate oil level reading on the dipstick. If I wait only 6 hours I get a bogus reading that is almost 1/3 quart on the low side. Is having to wait 12 hours to drain down into the pan after running excessive? Is this normal? I am using, and have always used, Castrol 20W-50 conventional oil and the ambient temp is around 85 degrees Fahrenheit. Running temps are normal as well as my CHT temps and I never find any excessive oil in the rebreather box. What have others experienced with this issue?
Ansbacher |
trick-e |
Oct 22 2020, 02:19 PM
Still Learning Group: Members Posts: 111 Joined: 7-July 12 From: Traverse City, MI USA Member No.: 14,644 Region Association: Upper MidWest |
I’ve a ‘73 2.0 and have always checked after getting up to operating temp, parking and powering down, then checking about 5-10 minutes later.
Ansbacher |
Oct 22 2020, 04:28 PM
JamesM |
Oct 22 2020, 05:43 PM
Senior Member Group: Members Posts: 1,888 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Do you have an external catch can or something? Cant think of anywhere in the motor itself that oil could get to that would take 12 hours to drain back.
Mark Henry |
Oct 22 2020, 06:24 PM
The 914 (bus, 411/412) has to be level, even small ground grade differences can wildly swing the oil level.
trick-e |
Oct 22 2020, 09:10 PM
I’ve a ‘73 2.0 and have always checked after getting up to operating temp, parking and powering down, then checking about 5-10 minutes later. Really? I always thought oil level was to be checked with the engine cold... Wrong?? Ansbacher Seems like I read numerous threads on this site, saw an Ian Karr recommendation on YouTube (https://m.youtube.com/watch?v=drmeeVKdGrk )and found this in the manual. ...and I’m open to a better idea. |
72hardtop |
Nov 2 2020, 08:00 AM
Member Group: Members Posts: 120 Joined: 11-September 13 From: Seattle/HB Ca./Fujieda-Japan Member No.: 16,378 Region Association: Pacific Northwest |
Very true with the T-4 engine. Even an unnoticeable slant will throw the reading off. Another over looked item is the anti drain back valve in an oil filter.
Bleyseng |
Nov 2 2020, 01:50 PM
You can overfill by a 1/2 qt too
brcacti |
Nov 2 2020, 02:39 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Right MUST be level if I have the rear wheels on on ramps it shows overfull
914_7T3 |
Nov 2 2020, 03:34 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,846 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
It seems with my car ('74 2.0L dual carbs) I must let the car sit for at least 12 hours to get an accurate oil level reading on the dipstick. If I wait only 6 hours I get a bogus reading that is almost 1/3 quart on the low side. Is having to wait 12 hours to drain down into the pan after running excessive? Is this normal? I am using, and have always used, Castrol 20W-50 conventional oil and the ambient temp is around 85 degrees Fahrenheit. Running temps are normal as well as my CHT temps and I never find any excessive oil in the rebreather box. What have others experienced with this issue? Ansbacher @Ansbacher As stupid as this sounds, its the same deal on my 73 2.0. If I check the oil reading the morning after a drive, I get a slightly higher reading on the dipstick. It makes no sense and checking oil levels is pretty straight forward, at least until now. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 26th April 2024 - 02:31 AM |
