2056 list of parts/work involved |
william1764 |
Oct 22 2020, 02:13 PM
Member Group: Members Posts: 252 Joined: 11-May 10 From: maryland Member No.: 11,717 Region Association: MidAtlantic Region |
Considering rebuilding my 2.0 to a 2056 or replacing engine with quality 2056 build already completed. Where can I find list of parts/work involved in a 2056 build? Thanks in advance!
VaccaRabite |
Oct 22 2020, 03:30 PM
En Garde! Group: Admin Posts: 13,450 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
At the very least you need a set of 96mm pistons and cylinders. That get you from a 2.0 to a 2056. If you run DJet now, you will be able to continue running DJET w/o changing all that much. You should expect a nice bump in power over a tired 2.0. Maybe about 115HP if you at least get heads done, maybe more depending on the build.
After that.... There is a lot you can upgrade. The single most important thing is the heads, and most of the money from your build will go into the heads. Zach |
Lo-Fi Version | Time is now: 28th May 2024 - 05:44 PM |
