QUOTE(william1764 @ Oct 22 2020, 12:13 PM)
Considering rebuilding my 2.0 to a 2056 or replacing engine with quality 2056 build already completed. Where can I find list of parts/work involved in a 2056 build? Thanks in advance!
"Rebuilding" because it needs to be rebuilt or rebuilding because you want to increase displacement?
Bare minimum to get to a 2056 if you have a running 2.0:
https://aapistons.com/collections/piston-li...-kit-914-type-4Technically you don't even need to split the case, just pull the heads and swap the P&Cs. That being said a 2056 becomes a lot more fun with the right cam and aftermarket injection.
If your motor "needs" a rebuild than what else you need is going to depend on what it looks like once you tear it down.
I know some people have a less than favorable view of the AA pistons but the ones in my EMW built 2056 autocross motor have held up to abuses that most would never subject their car to (see stints of 7000rpm), and i have seen a tame d-jet 2056 with KBs have a piston fail within the first 1000 miles due to fueling issues so i think as long as you QC the parts first and make sure your injection/tune is good you should be fine.
