2056 list of parts/work involved |
william1764 |
Oct 22 2020, 02:13 PM
Member Group: Members Posts: 252 Joined: 11-May 10 From: maryland Member No.: 11,717 Region Association: MidAtlantic Region |
Considering rebuilding my 2.0 to a 2056 or replacing engine with quality 2056 build already completed. Where can I find list of parts/work involved in a 2056 build? Thanks in advance!
JamesM |
Oct 22 2020, 05:22 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Considering rebuilding my 2.0 to a 2056 or replacing engine with quality 2056 build already completed. Where can I find list of parts/work involved in a 2056 build? Thanks in advance! "Rebuilding" because it needs to be rebuilt or rebuilding because you want to increase displacement? Bare minimum to get to a 2056 if you have a running 2.0: https://aapistons.com/collections/piston-li...-kit-914-type-4 Technically you don't even need to split the case, just pull the heads and swap the P&Cs. That being said a 2056 becomes a lot more fun with the right cam and aftermarket injection. If your motor "needs" a rebuild than what else you need is going to depend on what it looks like once you tear it down. I know some people have a less than favorable view of the AA pistons but the ones in my EMW built 2056 autocross motor have held up to abuses that most would never subject their car to (see stints of 7000rpm), and i have seen a tame d-jet 2056 with KBs have a piston fail within the first 1000 miles due to fueling issues so i think as long as you QC the parts first and make sure your injection/tune is good you should be fine. |
Lo-Fi Version | Time is now: 19th May 2024 - 08:52 AM |
