Oil Filter Intermediate Flange |
TX914 |
Oct 24 2020, 06:34 AM
Alan-B Group: Members Posts: 168 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None |
What is the torque spec for the oil filter intermediate flange nuts? The factory Workshop Manual doesn't specify. Bolts appear to be M8 so I'm guessing 14.5 ft/lb.
Also, what is the torque spec for the oil pressure switch (tapered threads)? Again the workshop manual doesn't specify. I'm using 6 ft/lb for the oil cooler nuts. Bentley Type 4 says 5 ft/lb, but there is still a question as to whether there should be a washer between case and cooler. On removal mine had 2 flat washers beneath the nut but none between case and cooler. I could not find a definitive answer any previous threads. Thanks, Alan B |
Mark Henry |
Oct 24 2020, 09:33 AM
What is the torque spec for the oil filter intermediate flange nuts? The factory Workshop Manual doesn't specify. Bolts appear to be M8 so I'm guessing 14.5 ft/lb. Also, what is the torque spec for the oil pressure switch (tapered threads)? Again the workshop manual doesn't specify. I'm using 6 ft/lb for the oil cooler nuts. Bentley Type 4 says 5 ft/lb, but there is still a question as to whether there should be a washer between case and cooler. On removal mine had 2 flat washers beneath the nut but none between case and cooler. I could not find a definitive answer any previous threads. Thanks, Alan B M6 7.5 ft/lbs in aluminum, up to 10 lbs in steel. I use an inch pound torque wrench. M8 up to 17 lbs No washer between the cooler, but does use a thicker washer under the nuts. |
TX914 |
Oct 24 2020, 05:04 PM
Thanks Mark. Would like to have seen the manual specify these since they’re often the source of oil leaks. Don’t want to be back in there anytime soon. Definite on the inch/lb torque wrench.
Cheers, Alan B |
Lo-Fi Version | Time is now: 18th May 2024 - 12:09 AM |
