What is the torque spec for the oil filter intermediate flange nuts? The factory Workshop Manual doesn't specify. Bolts appear to be M8 so I'm guessing 14.5 ft/lb.
Also, what is the torque spec for the oil pressure switch (tapered threads)? Again the workshop manual doesn't specify.
I'm using 6 ft/lb for the oil cooler nuts. Bentley Type 4 says 5 ft/lb, but there is still a question as to whether there should be a washer between case and cooler. On removal mine had 2 flat washers beneath the nut but none between case and cooler. I could not find a definitive answer any previous threads.
Thanks,
Alan B
