Rust repair before paint, The quest for solid metal in the driver side Long - 73 narrow body/4 rebuild thread |
Montreal914 |
Oct 24 2020, 05:59 PM
Senior Member Group: Members Posts: 1,559 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Edit: I might as well make this my rebuild thread...
Original post; I got side tracked on my Microsquirt build as I have decided, after 11 years of ownership, to finally get my car painted to get her ready for her upcoming 50th birthday. (IMG:style_emoticons/default/smile.gif) Knowing these endeavors can take a lot more time than initially planned, I hope to make it in time... (IMG:style_emoticons/default/wacko.gif) Originally bahia red 73 1.7. The goal is a narrow body 2056 Microsquirt, VW Tornado red, 5 lugs conversion with 16" Fuchs. Front: 914-4 A arms with rubber bushings, 911 3" pin struts, Bilstein inserts, Alfa Brembo, vented rotor, stock torsion bar, 19mm sway bar, turbo tie rods, and 19mm master cylinder. Rear: Drilled hubs, But before I get the pleasure of installing all of these beautiful fresh goodies, I need to tackle the not so fun stuff... (IMG:style_emoticons/default/headbang.gif) I have already started fixing some of the rust issues and will share that progress in the near future but right now, I wanted to post some of the issues i have on the passenger side front fender. (IMG:style_emoticons/default/sad.gif) I have searched and read many of the builds here but I would like some inputs from the people who have gone through this mess. I am trying to understand the construction of the rear part of the fender, more precisely the area joining the front cowling. Below is a sketch of how I think it is made but i would like someone to confirm... Having removed the seam sealer in the upper rear area, I have discovered "this" (IMG:style_emoticons/default/dry.gif) which is not really unusual, but clearly a pain to fix. I am not sure though what I am looking at. If my sketch is correct, I guess the inner rusted layer is from the fender rear bulkhead that actually becomes an inner layer on the rear upper point of the fender by the door and cowling junction. I might be able to cut this from the underside preventing me from cutting the outer surface of the fender. But I would like to better understand what is happening at the junction to the body. How many layers are there from the fender, one or two? Is the metal peeling off at the joint to the body the metal from the bulkhead/inner layer, or is it the outer fender layer? As a reference, this if the situation of the channel, surface rust, but how bad? Is there a way to better know without destroying? Maybe poke with a screwdriver? (IMG:style_emoticons/default/confused24.gif) Comments appreciated (IMG:style_emoticons/default/smile.gif) |
bbrock |
May 1 2021, 06:02 PM
I just got caught up. Fantastic work. I'm enjoying getting to ride along.
Now I have to ask, where is that boat now? That is epic! |
Montreal914 |
May 1 2021, 09:25 PM
I just got caught up. Fantastic work. I'm enjoying getting to ride along. Now I have to ask, where is that boat now? That is epic! @bbrock ; I am not sure of the current condition of the 24' long x 19' wide little trimaran made out of 3/16" thick plywood. I will ask him if he has fresh news from the new owners. In the early '80s, my dad traded it with extra money for a home built fiberglass foam sandwich 39' x 20' catamaran with a 45' mast from the same Australian designer. That one weighted 8,000lbs, which is still very light weight and very quick for that size sail boat. We enjoyed it as he improved it over the course of many years. He sold it a few years ago, as the maintenance and the navigation became too much for my parents who are now in their 80s. Below, picture taken in 2009 of him with our two daughters, a few month before our move to California. This was on lake Champlain upstate New York near the Canadian border. All this nautical distraction is very nice, but we are here to share about 914s (IMG:style_emoticons/default/biggrin.gif) So, what is the consensus on fixing the crack on the driver side inner long... (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 08:12 PM |
