Rust repair before paint, The quest for solid metal in the driver side Long - 73 narrow body/4 rebuild thread |
Montreal914 |
Oct 24 2020, 05:59 PM
Senior Member Group: Members Posts: 1,560 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Edit: I might as well make this my rebuild thread...
Original post; I got side tracked on my Microsquirt build as I have decided, after 11 years of ownership, to finally get my car painted to get her ready for her upcoming 50th birthday. (IMG:style_emoticons/default/smile.gif) Knowing these endeavors can take a lot more time than initially planned, I hope to make it in time... (IMG:style_emoticons/default/wacko.gif) Originally bahia red 73 1.7. The goal is a narrow body 2056 Microsquirt, VW Tornado red, 5 lugs conversion with 16" Fuchs. Front: 914-4 A arms with rubber bushings, 911 3" pin struts, Bilstein inserts, Alfa Brembo, vented rotor, stock torsion bar, 19mm sway bar, turbo tie rods, and 19mm master cylinder. Rear: Drilled hubs, But before I get the pleasure of installing all of these beautiful fresh goodies, I need to tackle the not so fun stuff... (IMG:style_emoticons/default/headbang.gif) I have already started fixing some of the rust issues and will share that progress in the near future but right now, I wanted to post some of the issues i have on the passenger side front fender. (IMG:style_emoticons/default/sad.gif) I have searched and read many of the builds here but I would like some inputs from the people who have gone through this mess. I am trying to understand the construction of the rear part of the fender, more precisely the area joining the front cowling. Below is a sketch of how I think it is made but i would like someone to confirm... Having removed the seam sealer in the upper rear area, I have discovered "this" (IMG:style_emoticons/default/dry.gif) which is not really unusual, but clearly a pain to fix. I am not sure though what I am looking at. If my sketch is correct, I guess the inner rusted layer is from the fender rear bulkhead that actually becomes an inner layer on the rear upper point of the fender by the door and cowling junction. I might be able to cut this from the underside preventing me from cutting the outer surface of the fender. But I would like to better understand what is happening at the junction to the body. How many layers are there from the fender, one or two? Is the metal peeling off at the joint to the body the metal from the bulkhead/inner layer, or is it the outer fender layer? As a reference, this if the situation of the channel, surface rust, but how bad? Is there a way to better know without destroying? Maybe poke with a screwdriver? (IMG:style_emoticons/default/confused24.gif) Comments appreciated (IMG:style_emoticons/default/smile.gif) |
Luke M |
Dec 15 2021, 02:34 PM
Senior Member Group: Members Posts: 1,372 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I've done both of these type of repairs. My brothers 914 did just that, section the rear q-panel. It was kinda of a pain to line things up just right. Took several tries but we did eventually get there. You can see where I cut and butt welded the panels together. Then cut for the flares. Getting the panels to mate just right is hard and it still doesn't look right. Bondo either way we look at it is gonna be the fix now. On my 6, I replaced the whole q-panel. It wasn't that much more work to do. Getting the panel off was the easy part. I cut off the panel then went back and removed the rest of the spot welds. Cut carefully in the targa area as you will cut into the inner support if you go too deep. If you can get your hands on a clean, rust free q-panel just replace it. Have you looked at your targa/door handle area yet? Mine looked great except it was filled with bondo over rust.
Attached image(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 03:04 AM |
