914/6 Front sway bars |
silverg |
Nov 6 2020, 12:07 PM
914s since March 1970 Group: Members Posts: 54 Joined: 7-June 06 From: Winchester, VA Member No.: 6,179 Region Association: MidAtlantic Region |
Did 914/6s come with sway bars or at least a triangular boss on the inner wheel well?
rgalla9146 |
Nov 6 2020, 12:21 PM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
neither
bdstone914 |
Nov 6 2020, 12:24 PM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
SKL1 |
Nov 6 2020, 12:43 PM
Senior Member Group: Members Posts: 1,600 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
I believe all 914's had the triangular boss on the inner fender well. I retrofitted F&R factory bars on my real '71 6 when I had it and it definitely had the boss. (main mistake was ever selling that car in the first place!!)
914Sixer |
Nov 6 2020, 12:56 PM
914 Guru Group: Members Posts: 8,879 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
All cars have the boss in place in the front. Rears require welding in bracket.
silverg |
Nov 6 2020, 01:10 PM
what does it mean if a 1970 mid-run 914/6 does not have the sway bar mounting boss - replaced fenders? Not a 6? Porsche oddity?
gandalf_025 |
Nov 6 2020, 01:46 PM
Senior Member Group: Members Posts: 1,453 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
All Aftermarket rear bars did not require welding.
H+H bars did not.. I put both front and rear H+H sway bars on my 6 in the mid 70’s And neither required welding and the front bar didn’t require removing the gas tank. I bought both directly from H+H , driving to the house of the owner to pick them up.. My car had the indent for bar in the front wheel well and the tabs on the A arms for them though.. |
Nov 6 2020, 02:25 PM
914-6 GT in waiting Group: Members Posts: 19,262 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
what does it mean if a 1970 mid-run 914/6 does not have the sway bar mounting boss - replaced fenders? Not a 6? Porsche oddity? Boss vs mount Pic is from my non sway bar 1970 parts car They all have a boss. Only the equipped cars have a mount. I believe the boss was made so the sway bar mounting plates will be parallel. All the early 914-4’s also had the mount on the a-arms even though they didn’t have the bar. I’m not sure about 6’s. Later cars only had a arm mounts if they had a factory bar. Attached thumbnail(s) |
Eric_Shea |
Nov 6 2020, 03:55 PM
No bars came on -6's
rgalla9146 |
Nov 6 2020, 04:39 PM
No bars came on -6's Thank you Eric. I was bit concerned there. Every car has the recess stamped into the inner fended. Later cars ( ~?) had a thread plate inside below the gas tank to facilitate front bar install. The U bracket on the lower control seems a bit random to me. Pictured is a stock six in my driveway tonight. Dirtiest I've ever owned. No bars. Blue parts are from a '75 (blue car, WHITE interior) Attached thumbnail(s) |
dr914@autoatlanta.com |
Nov 6 2020, 05:30 PM
914 Guru Group: Members Posts: 7,850 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
The 70 and 71 sixes did not have sway bars. 1972 sixes had them available as an option 16 in the front 15 in the rear
914-4 cylinder cars had sway bars available first in 73 15 front 16 rear, standard equipment on all 73 2.0 optional on all others a arms were intermixed throughout the years sway bars or not, some had the brackets some did not, whatever the factory was supplied with at the time of the cars production |
fixer34 |
Nov 6 2020, 07:59 PM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
silverg |
Nov 6 2020, 08:44 PM
I still don't know what to make of a mid-run 1970 914-6 without the front inner fender sway bar mounting boss?
Just a Porsche oddity? |
914werke |
Nov 6 2020, 09:15 PM
"I got blisters on me fingers" Group: Members Posts: 10,057 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
a-arms were intermixed throughout the years sway bars or not, some had the brackets some did not, whatever the factory was supplied with at the time of the cars production (IMG:style_emoticons/default/agree.gif) Ive even encountered cars with only one side or the other equipped with bracketed A-arms ...from all appearances OE (IMG:style_emoticons/default/confused24.gif) |
burton73 |
Nov 7 2020, 03:56 PM
burton73 Group: Members Posts: 3,517 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Number 41 clear clean picture of early 6
Bob B |
Nov 7 2020, 05:27 PM
except for the link 911 sway bars were the same. Question is do you have a rear sway bar? Factory did not install sway bars only on one end.
Secondly the six benefited from a front sway bar as it was tail happy. Third, the sway bar on your car is a factory one but could have been from a 911 or taken from a 914 73 and up. Many many installed at least a front sway bar on the sixes. What size it it (can measure with an open end metric wrench I'll enter the fray.. Pictures are of my factory March 1970 -6. I have had the car for 43 years and the sway bar was there when I bought it. So if it wasn't factory installed, maybe dealer? Can anyone identify the brand? You can tell it needs some new rubber... |
rgalla9146 |
Nov 8 2020, 06:31 AM
Keep in mind 914 6s were not for everyone. The person who sought a 6 typically wasn't driven by style or profile. They sought handling and 911 power. No sway bar ? easy install. Problem solved. That applied to the first owner and all succeding owners. |
Al Meredith |
Nov 8 2020, 11:21 AM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I just got The new 914 book on restoration from George Hussey and Dr. Johnson and is very good at explaining the differences between a 4 and a 6. The sway bar issue is clear on page 21,107,108 Great info , get the book! AL
SKL1 |
Nov 8 2020, 10:16 PM
Yes it is- got my signed copy as a contributor!!
fixer34 |
Nov 9 2020, 06:13 PM
except for the link 911 sway bars were the same. Question is do you have a rear sway bar? Factory did not install sway bars only on one end. Secondly the six benefited from a front sway bar as it was tail happy. Third, the sway bar on your car is a factory one but could have been from a 911 or taken from a 914 73 and up. Many many installed at least a front sway bar on the sixes. What size it it (can measure with an open end metric wrench I'll enter the fray.. Pictures are of my factory March 1970 -6. I have had the car for 43 years and the sway bar was there when I bought it. So if it wasn't factory installed, maybe dealer? Can anyone identify the brand? You can tell it needs some new rubber... George, I'm guessing you want the diameter of the sway bar itself, not the links. Any way to get that without pulling the tank? Yes, it certainly looks just like the diagram in the book of the factory sway bar.. But, no rear sway bar. Not even brackets or holes where it might have been. I have no history for the first 7 years of its life, just the seller's name and a hand-written bill of sale when I bought it. Factory owner's manual, but no dealer info. FWIW, everything914 is supposed to have records for all the US imported -6's. I checked, mine comes up blank. No info at all. But it is definately a US spec. I also have a signed copy of the book. That's my engine on page 92 (upper right). |
Lo-Fi Version | Time is now: 13th May 2024 - 03:26 AM |
