V8 Unconversion? |
V8 Unconversion? |
zprovo |
Nov 7 2020, 09:23 PM
Newbie Group: Members Posts: 19 Joined: 16-September 20 From: Nashville TN Member No.: 24,697 Region Association: South East States |
Anyone performed a flat 4 swap on a v8 swapped 914?
I'm sure a v8 is fun, but not my thing. I'm wondering how hard it would be to convert one back. |
76-914 |
Nov 7 2020, 10:51 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,496 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I’ve unconverted one, so to speak. I put a Subaru 6 in its place. I’d recommend you do the same unless you enjoy working and tinkering instead of driving. Depending upon your needs you can spend $3500-$7500 rebuilding a Type 4. I can replace an entire Subaru 6 engine for less than $1000. Just my opinion. If your doing a restoration and looking for originality then go aircooled. But I’ll bet you’ll need to patch some sheet metal that was cut out for the V8 conversion. If you go back with another water cooled set up then a lot of the work has already been done. Why not post some pics of your project. Whether you go water cooled or air sucker they’re a blast to drive. (IMG:style_emoticons/default/beerchug.gif)
Mike Bellis |
Nov 7 2020, 11:16 PM
Andyrew |
Nov 8 2020, 08:31 AM
Depends on what they did with the electrical and the mounts. If all the factory stuff is there it should be a straight forward swap.
Chris914n6 |
Nov 8 2020, 03:49 PM
Jackstands are my life. Group: Members Posts: 3,316 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Besides the holes in the front trunk sheetmetal, it will likely have the firewall engine shelf cut off for clearance and maybe the sides, so all that will need to be sourced and welded in before it will work as an aircooled again.
Like as has been said, do a Subaru flat 6 swap -- all the benefits of a Porsche 6 swap but budget friendly. |
zprovo |
Nov 9 2020, 01:31 PM
Thank you all for the input! The car sold, so on to the next one.
76-914 |
Nov 10 2020, 04:44 PM
Besides the holes in the front trunk sheetmetal, it will likely have the firewall engine shelf cut off for clearance and maybe the sides, so all that will need to be sourced and welded in before it will work as an aircooled again. Like as has been said, do a Subaru flat 6 swap -- all the benefits of a Porsche 6 swap but budget friendly. AND........ you don't need to cut out the shelve's when doing a Suby 6. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 10th May 2024 - 03:19 PM |
