2.0 or more, Bigger is better |
930cabman |
Nov 14 2020, 05:07 PM
Advanced Member Group: Members Posts: 3,007 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I cut my wrenching teeth on VW bugs and Type 3's back in the '70's and '80's. Been somewhat out of the game for several years looking to rejoin into the 914 world. Generally the easiest way for more kick is to increase displacement. Short of going to turbo's what is available as far as big bore kits. I am not interested in going the 6 cylinder route or chevy small block route. The car will be street only, but I need speed.
Tdskip |
Nov 18 2020, 09:17 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Oil tank, Wiring, front mounted engine cooler, lines and fittings to get the oil back-and-forth to the front mounted oil cooler, thermostat, Engine 10 in seals , revised engine mount in some brain damage on the right way to approach that, exhaust, shifter set up and linkage, muffler...
It all adds up. Quickly. And in large amounts of cubic dollars. |
930cabman |
Nov 19 2020, 12:04 AM
Oil tank, Wiring, front mounted engine cooler, lines and fittings to get the oil back-and-forth to the front mounted oil cooler, thermostat, Engine 10 in seals , revised engine mount in some brain damage on the right way to approach that, exhaust, shifter set up and linkage, muffler... It all adds up. Quickly. And in large amounts of cubic dollars. "Easy peasy", I can work with that. If it was done 50 years ago, how hard can it be today. The $$ just need to be worked out it terms of enjoyment. Thanks to all for the replies, we are scheduled to pickup the hulk this weekend and a 2.7 just might find its way into the bed of my F150. Its on the way and the right price |
Tdskip |
Nov 19 2020, 08:30 AM
Oil tank, Wiring, front mounted engine cooler, lines and fittings to get the oil back-and-forth to the front mounted oil cooler, thermostat, Engine 10 in seals , revised engine mount in some brain damage on the right way to approach that, exhaust, shifter set up and linkage, muffler... It all adds up. Quickly. And in large amounts of cubic dollars. "Easy peasy", I can work with that. If it was done 50 years ago, how hard can it be today. The $$ just need to be worked out it terms of enjoyment. Thanks to all for the replies, we are scheduled to pickup the hulk this weekend and a 2.7 just might find its way into the bed of my F150. Its on the way and the right price Go for it but keep in mind that mag case engines can be spendy to get fully/properly rebuild (if that is eve needed). Keep us posted and good luck! |
Lo-Fi Version | Time is now: 3rd May 2024 - 12:17 PM |
