2.0 or more, Bigger is better |
930cabman |
Nov 14 2020, 05:07 PM
Advanced Member Group: Members Posts: 3,007 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I cut my wrenching teeth on VW bugs and Type 3's back in the '70's and '80's. Been somewhat out of the game for several years looking to rejoin into the 914 world. Generally the easiest way for more kick is to increase displacement. Short of going to turbo's what is available as far as big bore kits. I am not interested in going the 6 cylinder route or chevy small block route. The car will be street only, but I need speed.
Tdskip |
Nov 18 2020, 09:17 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Oil tank, Wiring, front mounted engine cooler, lines and fittings to get the oil back-and-forth to the front mounted oil cooler, thermostat, Engine 10 in seals , revised engine mount in some brain damage on the right way to approach that, exhaust, shifter set up and linkage, muffler...
It all adds up. Quickly. And in large amounts of cubic dollars. |
ClayPerrine |
Nov 19 2020, 12:34 PM
Life's been good to me so far..... Group: Admin Posts: 15,430 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Oil tank, Wiring, front mounted engine cooler, lines and fittings to get the oil back-and-forth to the front mounted oil cooler, thermostat, Engine 10 in seals , revised engine mount in some brain damage on the right way to approach that, exhaust, shifter set up and linkage, muffler... It all adds up. Quickly. And in large amounts of cubic dollars. You don't absolutely have to have a front mounted oil cooler. I don't have one. But you do need a bigger oil cooler if you want to put it in the back. The 4.0 has two 964 coolers mounted in the rear, one on each side. Temps run 190 to 210. They went up a little when I put the rear valance on. For a 2.7, a 911 Carrera cooler mounted in the left rear corner works fine. I ran one on the 2.4 for years with no issues. |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:00 AM |
