my car is killing me, literally |
bd1308 |
Jul 15 2005, 01:38 PM
my car keeps on shitting oil and i cant breathe and i get headaches whenever i drive the car......
HELP! |
bd1308 |
Jul 15 2005, 01:57 PM
okay i am goign to drain and flush my oil sysstem and put 20W oil in there.......that way i have no extra crap in there......
its happening tongiht. |
gklinger |
Jul 15 2005, 02:02 PM
doh! Group: Members Posts: 316 Joined: 14-January 03 From: Tempe, AZ Member No.: 146 Region Association: Southwest Region |
quick! sell the car before you die!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/givemebeer.gif)
Jul 15 2005, 02:04 PM
Resident German Group: Admin Posts: 41,631 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
alright ... where is the oil coming from?
davep |
Jul 15 2005, 02:06 PM
914 Historian Group: Benefactors Posts: 5,141 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Pinky's revenge
Jul 15 2005, 02:07 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I'm thinking his earlier post about "how do I stop the pushrod tubes from leaking without replacing the seals" is a big hint on that question, Aaahndy.
--DD |
Mueller |
Jul 15 2005, 02:11 PM
WHICH THREAD??? He's only asked/mentioned the leaking seals about 5 times...we've all told him what "has" to be done.... fix it correctly or shut-up about it (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
bd1308 |
Jul 15 2005, 02:13 PM
no way the revenge was when my engine died.
pushrod tube. but its just a very small drip from one tube seal..... i wish somebody made a heat shield for these things.... |
Jul 15 2005, 02:17 PM
i guess i should have put a smily in my post ... daaaaaaave, i know! that's why i posted my previous post! i knew! i had read his earlier posts! (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) Andy |
bd1308 |
Jul 15 2005, 02:24 PM
i got paid today...monday the car is getting new stuff.
mikerose |
Jul 15 2005, 04:08 PM
Happy to be back Group: Members Posts: 657 Joined: 31-December 02 From: Pittsburg,ca Member No.: 60 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/slap.gif) LOL |
Allan |
Jul 15 2005, 04:16 PM
You'll probably be okay as long as the weather stays below freezing.... (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) |
airsix |
Jul 15 2005, 04:18 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
You could take the flapper boxes off the heater tubes and jam spray-paint can caps over the tubes (a perfect fit). That will keep the smoke out of the car at the expense of losing the heater.
Or you could just replace the pushrod tube seals like a man and be done with it. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) -Ben M. |
Aaron Cox |
Jul 15 2005, 04:47 PM
REPLACE THE FUCKING SEALS AND YOUR PROBLEMS GO AWAY. DO NOT ASK HOW TO STOP YOUR LEAK AGAIN. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
fuch toy |
Jul 15 2005, 04:49 PM
Unregistered |
Blanket party?
scotty b |
Jul 15 2005, 04:58 PM
Britt I'm opny going to suggest this to you this one more time. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Buy a gasket kit, drop the engine and replace ALL of the gaskets!! You will know they are all good (assuming they are installed properly) Theoretically this SHOULD have been done before the engine was put it BUT it wasn't so do it now and be done with it.
Mr.C |
Jul 15 2005, 06:38 PM
Easy does it Group: Members Posts: 611 Joined: 31-December 02 From: Central Cal Member No.: 61 Region Association: None |
D A N G! (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/owned.gif) |
bd1308 |
Jul 15 2005, 06:39 PM
okay....thanks guys. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) seriously. I'm just new to engine work.....I will order a gasket set. Usual Sources have them?
aaron, you dont have to respond ya know? |
airsix |
Jul 16 2005, 12:28 AM
I don't think you need a whole gasket set and I don't think you need to drop the motor.
The usual suspects: Valve cover gaskets Push-rod tube seals (get Viton seals!) Distributor O-ring Oil pressure sender (not a gasket, but they often leak) Oil cooler seals (least likely to leak and do require a motor drop*) You can get all of the above for very cheap and cure 99% of 914 oil leaks. (main seals would be the other 1% and require an engine drop) ...and when you said 20w oil I hope you meant 20w-50. -Ben M. *Can be done without dropping motor, but much easier if you do. There is a high suicide rate among those who do this repair without dropping the motor. (I'm a survivor) |
Lo-Fi Version | Time is now: 11th May 2024 - 10:16 PM |
