New video Sunday, Part 3 of my 2056 engine rebuild...and setback. |
iankarr |
Nov 15 2020, 10:25 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
It's new video sunday. Part 3 of my 2056 engine rebuild. Some of it didn't go as planned (IMG:style_emoticons/default/wink.gif).
Enjoy. https://www.youtube.com/watch?v=I0f2Yt5L2CU |
BeatNavy |
Nov 15 2020, 11:29 AM
Sorry, Ian. More time and $$ required (IMG:style_emoticons/default/pinch.gif)
Superhawk996 |
Nov 15 2020, 01:04 PM
914 Guru Group: Members Posts: 5,801 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
(IMG:style_emoticons/default/headbang.gif)
Hurts to see this. (IMG:style_emoticons/default/barf.gif) Hope you get it resolved quickly! |
simonjb |
Nov 15 2020, 05:11 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
Ugh - that sucks a bit - but I know the feeling.
I have also just finished my first rebuild and am dropping at the shop to do the first start up.... (IMG:style_emoticons/default/popcorn[1].gif) Great Videos.... |
914-300Hemi |
Nov 15 2020, 09:20 PM
Senior Member Group: Members Posts: 1,356 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California |
Great video. Curious as to see what went wrong.
Marmeli |
Nov 15 2020, 11:23 PM
Newbie Group: Members Posts: 1 Joined: 28-August 20 From: Ann Arbor, MI Member No.: 24,638 Region Association: Upper MidWest |
Good luck getting this fixed. Helpful videos - planning a rebuild on my 2.0 as well.
Montreal914 |
Nov 16 2020, 12:26 AM
Senior Member Group: Members Posts: 1,552 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
(IMG:style_emoticons/default/dry.gif) I hope it is not too bad.
When I did my 2056, I must have closed the case 2-3 times before sealing it, just to check all of this (empty with bearing only, then add crank, ...). I ran into a similar situation where my align bore was not done right (not deep enough in the middle bearing). Everything has to be checked... (IMG:style_emoticons/default/sad.gif) Following with interest. Thank you for preparing these videos! (IMG:style_emoticons/default/popcorn[1].gif) |
JOEPROPER |
Nov 16 2020, 07:23 AM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
(IMG:style_emoticons/default/headbang.gif) Ugh. Maybe just a small problem. Hope it's resolved easily. (IMG:style_emoticons/default/icon8.gif)
iankarr |
Nov 16 2020, 01:22 PM
All good. Just part of the process. And why it takes a while to do anything right.
Appreciate all of the suggestions and feedback here and on YouTube. This community never ceases to amaze. I should hear from the machinist this weeks and will keep y’all posted... |
Maury4 |
Nov 16 2020, 02:10 PM
Newbie Group: Members Posts: 26 Joined: 15-October 15 From: SC Member No.: 19,265 Region Association: South East States |
All good. Just part of the process. And why it takes a while to do anything right. Appreciate all of the suggestions and feedback here and on YouTube. This community never ceases to amaze. I should hear from the machinist this weeks and will keep y’all posted... I suspect rear bearing rotated out of dowel pin or the others up front. Ruined a set myself that way. Rick Maury |
Bleyseng |
Nov 16 2020, 02:50 PM
All good. Just part of the process. And why it takes a while to do anything right. Appreciate all of the suggestions and feedback here and on YouTube. This community never ceases to amaze. I should hear from the machinist this weeks and will keep y’all posted... I suspect rear bearing rotated out of dowel pin or the others up front. Ruined a set myself that way. Rick Maury I'll bet that's it too! (IMG:style_emoticons/default/piratenanner.gif) |
iankarr |
Nov 16 2020, 08:03 PM
Definitely possible. But I triple checked how everything was seated...and the rub marks inside the thrust bearing were 90 degrees from the dowel pin. Will report back once I hear from the shop...
Frankvw |
Nov 17 2020, 10:52 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
Ian, I had the same many years ago assembling a beetle case.
Got stuck while tightening the case bolts. I did not try it half way like you did, so after the torqueing I was looking very proud what I had achieved only to find up it was locked up, just like you have. I split the case and found a bearing that moved and the dowelpin pressed itself in the bearing while tightening the bolts. Really, it pressed a new dowelhole in there. So...I got a new bearing and redid it. Same thing...but now I found out while tightening....but already too late, another bearing unusable, again the bearing seemed to have moved away from the dowelpin. I ordered another one, and now in the correct size (IMG:style_emoticons/default/smile.gif) Measuring is so important (besides cleaning) since the tolerances are critical. Good luck with the build, it is super great to see you building this engine. |
Lo-Fi Version | Time is now: 12th May 2024 - 03:06 PM |
